Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement
  1. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement, Recoil Starter: step 1, image 1 of 1
    • Remove the four screws from the hood of the lawnmower using a Phillips #0 screwdriver.
  2. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 2, image 1 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 2, image 2 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 2, image 3 of 3
    • Remove the hood of the lawnmower by pulling up.
  3. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 3, image 1 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 3, image 2 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 3, image 3 of 3
    • Using a wrench, remove the three nuts from the lawnmower’s defective recoil starter.
  4. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 4, image 1 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 4, image 2 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 4, image 3 of 3
    • Remove the defective recoil starter by pulling up.
  5. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 5, image 1 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 5, image 2 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 5, image 3 of 3
    • Place the new recoil starter in the lawnmower where the defective one was prior.
  6. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 6, image 1 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 6, image 2 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 6, image 3 of 3
    • Tighten the new recoil starter onto the lawnmower with a wrench and the nuts you had removed earlier.
  7. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 7, image 1 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 7, image 2 of 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: step 7, image 3 of 3
    • Tighten the hood back onto the lawnmower with a Phillips #0 screwdriver and the four screws you had removed previously.
    • Make sure not to screw the hood on too tightly.
Finish Line
Andres Dominguez
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 79
All Time: 1,945
