Cuisinart DCC-1100 Power Cord Replacement
  1. Cuisinart DCC-1100 Power Cord Replacement, Power Cord: step 1, image 1 of 2 Cuisinart DCC-1100 Power Cord Replacement, Power Cord: step 1, image 2 of 2
    • Unplug the maker, remove the coffee pot, and flip upside down.
  2. Cuisinart DCC-1100 Power Cord Replacement: step 2, image 1 of 2 Cuisinart DCC-1100 Power Cord Replacement: step 2, image 2 of 2
    • Remove the five 1.6mm Phillips #1 screws from the bottom panel.
    • Remove the bottom panel.
  3. Cuisinart DCC-1100 Power Cord Replacement: step 3, image 1 of 2 Cuisinart DCC-1100 Power Cord Replacement: step 3, image 2 of 2
    • Push the power cord inward and away from the plastic protection plate.
  4. Cuisinart DCC-1100 Power Cord Replacement: step 4, image 1 of 2 Cuisinart DCC-1100 Power Cord Replacement: step 4, image 2 of 2
    • Remove the two 1.4mm Phillips #0 screws from the plastic protection plate.
    • Remove the plastic protection plate.
  5. Cuisinart DCC-1100 Power Cord Replacement: step 5, image 1 of 3 Cuisinart DCC-1100 Power Cord Replacement: step 5, image 2 of 3 Cuisinart DCC-1100 Power Cord Replacement: step 5, image 3 of 3
    • Remove the two 1.6mm Phillips #1 screws from the heating element.
    • Using a flathead screwdriver to remove the outer clips holding the heating unit in place.
    • Flip the heating element up to allow access to the circuit board.
  6. Cuisinart DCC-1100 Power Cord Replacement: step 6, image 1 of 2 Cuisinart DCC-1100 Power Cord Replacement: step 6, image 2 of 2
    • Pull out the circuit board and rest it on the side of the machine.
    • Desolder the power cable from the motherboard.
Nicholas Eales
272 Reputation
1 Guide authored
USF Tampa, Team S20-G4, Passmore Spring 2018 Member of USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 1,962
