Cuisinart DCC-1100 Selection Knob Replacement
  1. Cuisinart DCC-1100 Selection Knob Replacement, Selection Knob: step 1, image 1 of 2 Cuisinart DCC-1100 Selection Knob Replacement, Selection Knob: step 1, image 2 of 2
    • Remove the coffee pot.
  2. Cuisinart DCC-1100 Selection Knob Replacement: step 2, image 1 of 2 Cuisinart DCC-1100 Selection Knob Replacement: step 2, image 2 of 2
    • Open the lid.
    • Remove the two 1.6mm Phillips #1 screws from the lid.
  3. Cuisinart DCC-1100 Selection Knob Replacement: step 3, image 1 of 1
    • Remove the lid from the coffee maker.
  4. Cuisinart DCC-1100 Selection Knob Replacement: step 4, image 1 of 1
    • Remove the two 1.3mm screws from the display.
  5. Cuisinart DCC-1100 Selection Knob Replacement: step 5, image 1 of 2 Cuisinart DCC-1100 Selection Knob Replacement: step 5, image 2 of 2
    • Push the display into the maker so that way you can access the screws in the back.
    • Remove the four 1mm Phillips #0 screws from the back.
  6. Cuisinart DCC-1100 Selection Knob Replacement: step 6, image 1 of 2 Cuisinart DCC-1100 Selection Knob Replacement: step 6, image 2 of 2
    • Remove the back panel.
    • Remove the front panel from the display.
  7. Cuisinart DCC-1100 Selection Knob Replacement: step 7, image 1 of 1
    • Remove the three 1mm Phillips #0 screws from the knob.
  8. Cuisinart DCC-1100 Selection Knob Replacement: step 8, image 1 of 1
    • Remove the knob from the front panel.
  9. Cuisinart DCC-1100 Selection Knob Replacement: step 9, image 1 of 1
    • Remove the plastic ring from the knob.
Josh Harvey
889 Reputation
4 Guides authored
USF Tampa, Team S20-G4, Passmore Spring 2018 Member of USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 11
All Time: 898
