Cuisinart DFP-14BCN Power Cord Replacement
  1. Cuisinart DFP-14BCN Power Cord Replacement, Bowl: step 1, image 1 of 3 Cuisinart DFP-14BCN Power Cord Replacement, Bowl: step 1, image 2 of 3 Cuisinart DFP-14BCN Power Cord Replacement, Bowl: step 1, image 3 of 3
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Power Cord Replacement: step 2, image 1 of 1
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Power Cord Replacement: step 3, image 1 of 3 Cuisinart DFP-14BCN Power Cord Replacement: step 3, image 2 of 3 Cuisinart DFP-14BCN Power Cord Replacement: step 3, image 3 of 3
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Power Cord Replacement: step 4, image 1 of 1
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Power Cord Replacement: step 5, image 1 of 3 Cuisinart DFP-14BCN Power Cord Replacement: step 5, image 2 of 3 Cuisinart DFP-14BCN Power Cord Replacement: step 5, image 3 of 3
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Power Cord Replacement, Back Casing: step 6, image 1 of 2 Cuisinart DFP-14BCN Power Cord Replacement, Back Casing: step 6, image 2 of 2
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Power Cord Replacement: step 7, image 1 of 2 Cuisinart DFP-14BCN Power Cord Replacement: step 7, image 2 of 2
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Power Cord Replacement: step 8, image 1 of 3 Cuisinart DFP-14BCN Power Cord Replacement: step 8, image 2 of 3 Cuisinart DFP-14BCN Power Cord Replacement: step 8, image 3 of 3
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Power Cord Replacement: step 9, image 1 of 2 Cuisinart DFP-14BCN Power Cord Replacement: step 9, image 2 of 2
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Power Cord Replacement, Power Cord: step 10, image 1 of 3 Cuisinart DFP-14BCN Power Cord Replacement, Power Cord: step 10, image 2 of 3 Cuisinart DFP-14BCN Power Cord Replacement, Power Cord: step 10, image 3 of 3
    • Unlatch the power cord from its casing at the bottom left corner of the base by lifting the cord upward.
  11. Cuisinart DFP-14BCN Power Cord Replacement: step 11, image 1 of 3 Cuisinart DFP-14BCN Power Cord Replacement: step 11, image 2 of 3 Cuisinart DFP-14BCN Power Cord Replacement: step 11, image 3 of 3
    • Use flat pliers to clamp down on the wide part of the plastic covering located at the power cord's white wire connection.
    • Pull the plastic cover off of the wire by keeping the pliers clamped down and pulling away from the wires.
    • This may require some force.
    • Repeat for the power cord's brown wire connection.
  12. Cuisinart DFP-14BCN Power Cord Replacement: step 12, image 1 of 2 Cuisinart DFP-14BCN Power Cord Replacement: step 12, image 2 of 2
    • Use wire cutters to cut the exposed wire on the power cord's white wire. To cut the wire, position the blades of the wire cutter over the exposed wire and clamp down.
    • Repeat for the power cord's brown wire connection. This cuts off the connection between the power cord and motor.
    • Pull the power cord out. It is no longer attached to the device.
    • For reassembly, the wires will need to be soldered together. Check out this soldering guide for instructions.
Vanessa See
125 Reputation
2 Guides authored
Cal Poly, Team 10-3, Livingston Fall 2016 Member of Cal Poly, Team 10-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G3
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 61
All Time: 2,645
