Cuisinart DGB-650 Motherboard Replacement
  1. Cuisinart DGB-650 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Cuisinart DGB-650 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Cuisinart DGB-650 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Turn the coffee maker upside down.
    • Remove the four 1.2 mm screws using a Phillips #0 screwdriver.
    • Remove the bottom cover to expose the heating element and pipes.
  2. Cuisinart DGB-650 Motherboard Replacement: step 2, image 1 of 3 Cuisinart DGB-650 Motherboard Replacement: step 2, image 2 of 3 Cuisinart DGB-650 Motherboard Replacement: step 2, image 3 of 3
    • Firmly grasp both pipe endings next to the motherboard and gently pull both ends out.
  3. Cuisinart DGB-650 Motherboard Replacement: step 3, image 1 of 3 Cuisinart DGB-650 Motherboard Replacement: step 3, image 2 of 3 Cuisinart DGB-650 Motherboard Replacement: step 3, image 3 of 3
    • Remove the two 1.2 mm screws keeping the pipe clamp attached using a Phillips #0 screwdriver.
    • Lift the pipe clamp up and set it aside.
  4. Cuisinart DGB-650 Motherboard Replacement: step 4, image 1 of 3 Cuisinart DGB-650 Motherboard Replacement: step 4, image 2 of 3 Cuisinart DGB-650 Motherboard Replacement: step 4, image 3 of 3
    • Remove the lid to get access to the motherboard.
  5. Cuisinart DGB-650 Motherboard Replacement: step 5, image 1 of 2 Cuisinart DGB-650 Motherboard Replacement: step 5, image 2 of 2
    • Gently grasp and remove the expansion slot on the motherboard with the six colorful wires intertwined together.
    • Gently grasp and remove the expansion slot.
  6. Cuisinart DGB-650 Motherboard Replacement: step 6, image 1 of 3 Cuisinart DGB-650 Motherboard Replacement: step 6, image 2 of 3 Cuisinart DGB-650 Motherboard Replacement: step 6, image 3 of 3
    • Use pliers to remove the plastic clamps from each of the six wires connected to the motherboard.
    • The motherboard should now be completely separated from the coffee maker.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 67
