Cuisinart Griddler GR- 4N Button Spring Replacement
  1. Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: step 1, image 1 of 2 Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: step 1, image 2 of 2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR- 4N Button Spring Replacement: step 2, image 1 of 1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR- 4N Button Spring Replacement: step 3, image 1 of 1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR- 4N Button Spring Replacement: step 4, image 1 of 1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR- 4N Button Spring Replacement: step 5, image 1 of 2 Cuisinart Griddler GR- 4N Button Spring Replacement: step 5, image 2 of 2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
  6. Cuisinart Griddler GR- 4N Button Spring Replacement, Button Spring: step 6, image 1 of 1
    • Depress one of the gray tabs on the side of the housing.
  7. Cuisinart Griddler GR- 4N Button Spring Replacement: step 7, image 1 of 1
    • Pull out the black button and the spring will also come out within it.
  8. Cuisinart Griddler GR- 4N Button Spring Replacement: step 8, image 1 of 1
    • Pull out the spring, and insert the replacement spring making sure it is correctly aligned.
3 other people completed this guide.
Laine Aro
173 Reputation
1 Guide authored
Cal Poly, Team 1-12, Maness Spring 2016 Member of Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 34
All Time: 4,310
