CyberPower UPS Battery Replacement
  1. CyberPower UPS Battery Replacement, Battery: step 1, image 1 of 2 CyberPower UPS Battery Replacement, Battery: step 1, image 2 of 2
    • Power down the unit by pressing the power button until the display goes black.
    • This is usually about 3 seconds.
    • Unplug the power cord from the wall outlet.
  2. CyberPower UPS Battery Replacement: step 2, image 1 of 3 CyberPower UPS Battery Replacement: step 2, image 2 of 3 CyberPower UPS Battery Replacement: step 2, image 3 of 3
    • Remove the battery plate cover at the bottom of the UPS using a Phillips #1 screwdriver.
    • If the screwdriver is not magnetized, tap on the cover plate to completely remove the screw.
  3. CyberPower UPS Battery Replacement: step 3, image 1 of 2 CyberPower UPS Battery Replacement: step 3, image 2 of 2
    • Slide the battery cover plate to the left.
    • Grasp the battery plate cover and lift it off the the UPS.
  4. CyberPower UPS Battery Replacement: step 4, image 1 of 3 CyberPower UPS Battery Replacement: step 4, image 2 of 3 CyberPower UPS Battery Replacement: step 4, image 3 of 3
    • Pull out the battery to expose the terminal connectors.
    • Use needlenose pliers to disconnect both battery terminal connectors.
    • Do not pull the connectors by the wires, pull connectors by grabbing the connector itself.
    • With the battery terminal connectors disconnected, slide the battery all the way out.
  5. CyberPower UPS Battery Replacement: step 5, image 1 of 3 CyberPower UPS Battery Replacement: step 5, image 2 of 3 CyberPower UPS Battery Replacement: step 5, image 3 of 3
    • The replacement battery should be a 12 volt, 9 amp-hour, sealed lead acid battery with f2 type connectors.
    • Install the new battery and reconnect the terminals.
  6. CyberPower UPS Battery Replacement: step 6, image 1 of 3 CyberPower UPS Battery Replacement: step 6, image 2 of 3 CyberPower UPS Battery Replacement: step 6, image 3 of 3
    • Insert the screw to secure the battery cover plate.
    • Tighten the screw with a Phillips #1 screwdriver.
  7. CyberPower UPS Battery Replacement: step 7, image 1 of 3 CyberPower UPS Battery Replacement: step 7, image 2 of 3 CyberPower UPS Battery Replacement: step 7, image 3 of 3
    • Plug system into the wall outlet.
    • Press the power button to turn on the unit.
3 other people completed this guide.
1 Guide Comment
This guide is very educative and helpful.
Philip Saviour - Reply
Past 24 Hours: 13
Past 7 Days: 77
Past 30 Days: 356
All Time: 18,650
