CyberPowerPC RGB 7 Color Key Replacement Replacement
  1. CyberPowerPC RGB 7 Color Key Replacement Replacement, Plastic Casing: step 1, image 1 of 2 CyberPowerPC RGB 7 Color Key Replacement Replacement, Plastic Casing: step 1, image 2 of 2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color Key Replacement Replacement: step 2, image 1 of 2 CyberPowerPC RGB 7 Color Key Replacement Replacement: step 2, image 2 of 2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color Key Replacement Replacement: step 3, image 1 of 1
    • Lift up and remove the plastic casing.
  4. CyberPowerPC RGB 7 Color Key Replacement Replacement, LED Backlight: step 4, image 1 of 1
    • Remove the metal backing located directly underneath the white plastic casing.
  5. CyberPowerPC RGB 7 Color Key Replacement Replacement: step 5, image 1 of 1
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  6. CyberPowerPC RGB 7 Color Key Replacement Replacement: step 6, image 1 of 1
    • Carefully remove the LED board, which should now come free from the casing.
  7. CyberPowerPC RGB 7 Color Key Replacement Replacement, Key Replacement: step 7, image 1 of 1
    • Now the cell membrane should be exposed, gently lift this part and ensure that the rubber buffers are all intact to the membrane, if not pick up the buffers and set to the side.
  8. CyberPowerPC RGB 7 Color Key Replacement Replacement: step 8, image 1 of 1
    • The keyboard should now be free to move, pick up the entire keyboard membrane and search for the key that needs to be replaced, to assist in remembering which key needs to be replaced place a small marker dot on the individual key back.
2 other people completed this guide.
Katherine Von Braunsberg
377 Reputation
3 Guides authored
USF Tampa, Team S15-G2, Boczar Spring 2018 Member of USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 Members
10 Guides authored
1 Guide Comment
Past 24 Hours: 7
Past 7 Days: 39
Past 30 Days: 119
All Time: 3,821
