D-Link DCS-5222L Motherboard Replacement
  1. D-Link DCS-5222L Motherboard Replacement, Motherboard: step 1, image 1 of 2 D-Link DCS-5222L Motherboard Replacement, Motherboard: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the four rubber feet on the bottom of the camera using your fingers or a pair of tweezers.
  2. D-Link DCS-5222L Motherboard Replacement: step 2, image 1 of 1
    • Using a #1 Phillips screwdriver, remove the four 7mm screws that are exposed by the removed feet.
  3. D-Link DCS-5222L Motherboard Replacement: step 3, image 1 of 2 D-Link DCS-5222L Motherboard Replacement: step 3, image 2 of 2
    • Using your hands, open the camera body by wiggling the bottom free from the upper shell.
    • Open the shell carefully, as the motherboard is attached to the bottom of the body; all of the components in the upper body are accordingly connected to the bottom. Likewise, the WiFi antenna is mounted to the upper shell, but a wire connects it to the motherboard on the bottom of the body.
  4. D-Link DCS-5222L Motherboard Replacement: step 4, image 1 of 3 D-Link DCS-5222L Motherboard Replacement: step 4, image 2 of 3 D-Link DCS-5222L Motherboard Replacement: step 4, image 3 of 3
    • Disconnect the five quick connections attaching the various cables to the motherboard with your fingers or blunt ended tweezers.
  5. D-Link DCS-5222L Motherboard Replacement: step 5, image 1 of 2 D-Link DCS-5222L Motherboard Replacement: step 5, image 2 of 2
    • Using your soldering iron, heat the antenna contacts on the motherboard until the wire releases.
    • Soldering Irons are hot and can burn you and ignite flammable materials.
  6. D-Link DCS-5222L Motherboard Replacement: step 6, image 1 of 1
    • Using a #1 Phillips screwdriver, remove the single 7mm screw holding the motherboard in place.
  7. D-Link DCS-5222L Motherboard Replacement: step 7, image 1 of 3 D-Link DCS-5222L Motherboard Replacement: step 7, image 2 of 3 D-Link DCS-5222L Motherboard Replacement: step 7, image 3 of 3
    • Wiggle free the motherboard from the bottom of the body.
    • There are two pegs that limit the motherboard's rotation. Have some patience when wiggling it free.
    • The power and ethernet ports have ledges along their top surface. These must be removed from the body at an angle relative to the horizontal.
Ryan Null
377 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 31
All Time: 1,099
