D-Link DCS-5222L Motor Replacement
  1. D-Link DCS-5222L Motor Replacement, Motors: step 1, image 1 of 3 D-Link DCS-5222L Motor Replacement, Motors: step 1, image 2 of 3 D-Link DCS-5222L Motor Replacement, Motors: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the four rubber feet on the bottom of the camera with tweezers.
    • Remove the four screws using a Phillips #1 screwdriver.
    • Remove the lower piece of the camera body.
  2. D-Link DCS-5222L Motor Replacement: step 2, image 1 of 2 D-Link DCS-5222L Motor Replacement: step 2, image 2 of 2
    • Remove the motherboard and bottom of the camera body.
    • Disconnect the five cables from the motherboard using tweezers.
  3. D-Link DCS-5222L Motor Replacement: step 3, image 1 of 2 D-Link DCS-5222L Motor Replacement: step 3, image 2 of 2
    • Use a #1 Phillips screwdriver to remove the two 7mm screws holding the motor in place.
  4. D-Link DCS-5222L Motor Replacement: step 4, image 1 of 2 D-Link DCS-5222L Motor Replacement: step 4, image 2 of 2
    • Using your hands, separate the bottom of the body from the upper portion.
  5. D-Link DCS-5222L Motor Replacement: step 5, image 1 of 2 D-Link DCS-5222L Motor Replacement: step 5, image 2 of 2
    • To remove the top of the camera you must push in the black tabs using the spudger. There are 3 tabs per side.
    • While pushing in the tabs, you can now lift the top black portion of the camera using your hands.
  6. D-Link DCS-5222L Motor Replacement: step 6, image 1 of 2 D-Link DCS-5222L Motor Replacement: step 6, image 2 of 2
    • With a little wiggle, the camera module will come free from the body.
    • Unscrew the two 7mm screws on the camera using a #1 Phillips screwdriver.
  7. D-Link DCS-5222L Motor Replacement: step 7, image 1 of 2 D-Link DCS-5222L Motor Replacement: step 7, image 2 of 2
    • Pry apart the camera housing with your fingers to reveal the second motor.
  8. D-Link DCS-5222L Motor Replacement: step 8, image 1 of 1
    • Unscrew the two 6mm screws holding the motor in place with a #1 Phillips screwdriver.
Jason Munyon
268 Reputation
2 Guides authored
2 Comments
Where can I buy new motor?
Michael Williams - Reply
I do not know, I purchased a “for Parts” camera on e-bay for $15.00 and used the motor from that unit.
Ed Wheelbarger - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 744
