D-Link DCS-825L Back Casing Replacement
  1. D-Link DCS-825L Back Casing Replacement, Accent Ring: step 1, image 1 of 1
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
  2. D-Link DCS-825L Back Casing Replacement: step 2, image 1 of 1
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
  3. D-Link DCS-825L Back Casing Replacement: step 3, image 1 of 1
    • Replace your accent ring with whichever color you choose.
  4. D-Link DCS-825L Back Casing Replacement, Back Casing: step 4, image 1 of 2 D-Link DCS-825L Back Casing Replacement, Back Casing: step 4, image 2 of 2
    • Remove one Phillips #2 screw from each side of the camera lens.
  5. D-Link DCS-825L Back Casing Replacement: step 5, image 1 of 3 D-Link DCS-825L Back Casing Replacement: step 5, image 2 of 3 D-Link DCS-825L Back Casing Replacement: step 5, image 3 of 3
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
  6. D-Link DCS-825L Back Casing Replacement: step 6, image 1 of 2 D-Link DCS-825L Back Casing Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
  7. D-Link DCS-825L Back Casing Replacement: step 7, image 1 of 3 D-Link DCS-825L Back Casing Replacement: step 7, image 2 of 3 D-Link DCS-825L Back Casing Replacement: step 7, image 3 of 3
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
April Ulrich
205 Reputation
2 Guides authored
USF Tampa, Team S1-G5, Leahy Fall 2018 Member of USF Tampa, Team S1-G5, Leahy Fall 2018
USFT-LEAHY-F18S1G5
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 410
