D-Link DIR-890L Heat Sink Replacement
  1. D-Link DIR-890L Heat Sink Replacement, Case: step 1, image 1 of 3 D-Link DIR-890L Heat Sink Replacement, Case: step 1, image 2 of 3 D-Link DIR-890L Heat Sink Replacement, Case: step 1, image 3 of 3
    • Peel off the four rubber rectangular feet with your fingers.
    • The feet may be hard to remove. Apply additional force if necessary.
  2. D-Link DIR-890L Heat Sink Replacement: step 2, image 1 of 3 D-Link DIR-890L Heat Sink Replacement: step 2, image 2 of 3 D-Link DIR-890L Heat Sink Replacement: step 2, image 3 of 3
    • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
  3. D-Link DIR-890L Heat Sink Replacement: step 3, image 1 of 3 D-Link DIR-890L Heat Sink Replacement: step 3, image 2 of 3 D-Link DIR-890L Heat Sink Replacement: step 3, image 3 of 3
    • Wedge the opening tool between the red top panel and the gray bottom panel.
    • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
  4. D-Link DIR-890L Heat Sink Replacement, Heat Sink: step 4, image 1 of 3 D-Link DIR-890L Heat Sink Replacement, Heat Sink: step 4, image 2 of 3 D-Link DIR-890L Heat Sink Replacement, Heat Sink: step 4, image 3 of 3
    • Unscrew the two 7mm screws with a Phillips #1 screwdriver.
    • Lift the heat sink off the metal plate with your fingers.
Michael Hilomen
201 Reputation
1 Guide authored
Cal Poly, Team 10-7, Livingston Fall 2016 Member of Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,211
