D-Link DIR-890L Power Switch Replacement
  1. D-Link DIR-890L Power Switch Replacement, Case: step 1, image 1 of 3 D-Link DIR-890L Power Switch Replacement, Case: step 1, image 2 of 3 D-Link DIR-890L Power Switch Replacement, Case: step 1, image 3 of 3
    • Peel off the four rubber rectangular feet with your fingers.
    • The feet may be hard to remove. Apply additional force if necessary.
  2. D-Link DIR-890L Power Switch Replacement: step 2, image 1 of 3 D-Link DIR-890L Power Switch Replacement: step 2, image 2 of 3 D-Link DIR-890L Power Switch Replacement: step 2, image 3 of 3
    • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
  3. D-Link DIR-890L Power Switch Replacement: step 3, image 1 of 3 D-Link DIR-890L Power Switch Replacement: step 3, image 2 of 3 D-Link DIR-890L Power Switch Replacement: step 3, image 3 of 3
    • Wedge the opening tool between the red top panel and the gray bottom panel.
    • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
  4. D-Link DIR-890L Power Switch Replacement, Motherboard: step 4, image 1 of 1
    • Orient the router so the narrow end of the router faces you and the ports face away from you.
    • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
  5. D-Link DIR-890L Power Switch Replacement: step 5, image 1 of 3 D-Link DIR-890L Power Switch Replacement: step 5, image 2 of 3 D-Link DIR-890L Power Switch Replacement: step 5, image 3 of 3
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
  6. D-Link DIR-890L Power Switch Replacement: step 6, image 1 of 2 D-Link DIR-890L Power Switch Replacement: step 6, image 2 of 2
    • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
  7. D-Link DIR-890L Power Switch Replacement: step 7, image 1 of 3 D-Link DIR-890L Power Switch Replacement: step 7, image 2 of 3 D-Link DIR-890L Power Switch Replacement: step 7, image 3 of 3
    • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
  8. D-Link DIR-890L Power Switch Replacement: step 8, image 1 of 3 D-Link DIR-890L Power Switch Replacement: step 8, image 2 of 3 D-Link DIR-890L Power Switch Replacement: step 8, image 3 of 3
    • Pull the yellow tape off of the motherboard to release the final antenna wire.
  9. D-Link DIR-890L Power Switch Replacement: step 9, image 1 of 2 D-Link DIR-890L Power Switch Replacement: step 9, image 2 of 2
    • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
  10. D-Link DIR-890L Power Switch Replacement, Power Switch: step 10, image 1 of 3 D-Link DIR-890L Power Switch Replacement, Power Switch: step 10, image 2 of 3 D-Link DIR-890L Power Switch Replacement, Power Switch: step 10, image 3 of 3
    • Locate the power switch on the top left of the motherboard.
    • The power switch is the component that sticks out the furthest.
    • Turn the motherboard upside down.
    • Locate the 6 solder joints that connect the power switch to the motherboard. They are arranged in 2 columns of 3.
  11. D-Link DIR-890L Power Switch Replacement: step 11, image 1 of 2 D-Link DIR-890L Power Switch Replacement: step 11, image 2 of 2
    Desoldering Pump
    $3.99
    Buy
    • Using a soldering iron and desoldering pump, desolder the power switch from the board.
    • For more information, see this guide on desoldering.
Rachel Shaw
553 Reputation
5 Guides authored
Cal Poly, Team 10-7, Livingston Fall 2016 Member of Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 1,272
