D-Link DIR-890L Reset Button Replacement
  1. D-Link DIR-890L Reset Button Replacement, Motherboard: step 1, image 1 of 1
    • Orient the router so the narrow end of the router faces you and the ports face away from you.
    • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
  2. D-Link DIR-890L Reset Button Replacement: step 2, image 1 of 3 D-Link DIR-890L Reset Button Replacement: step 2, image 2 of 3 D-Link DIR-890L Reset Button Replacement: step 2, image 3 of 3
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
  3. D-Link DIR-890L Reset Button Replacement: step 3, image 1 of 2 D-Link DIR-890L Reset Button Replacement: step 3, image 2 of 2
    • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
  4. D-Link DIR-890L Reset Button Replacement: step 4, image 1 of 3 D-Link DIR-890L Reset Button Replacement: step 4, image 2 of 3 D-Link DIR-890L Reset Button Replacement: step 4, image 3 of 3
    • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
  5. D-Link DIR-890L Reset Button Replacement: step 5, image 1 of 3 D-Link DIR-890L Reset Button Replacement: step 5, image 2 of 3 D-Link DIR-890L Reset Button Replacement: step 5, image 3 of 3
    • Pull the yellow tape off of the motherboard to release the final antenna wire.
  6. D-Link DIR-890L Reset Button Replacement: step 6, image 1 of 2 D-Link DIR-890L Reset Button Replacement: step 6, image 2 of 2
    • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
  7. D-Link DIR-890L Reset Button Replacement, Reset Button: step 7, image 1 of 3 D-Link DIR-890L Reset Button Replacement, Reset Button: step 7, image 2 of 3 D-Link DIR-890L Reset Button Replacement, Reset Button: step 7, image 3 of 3
    • Locate the reset switch at the top of the motherboard.
    • Flip the motherboard over.
    • Locate the reset switch's 4 solder joints on the underside of the motherboard.
  8. D-Link DIR-890L Reset Button Replacement: step 8, image 1 of 1
    Desoldering Pump
    $3.99
    Buy
    • Using a soldering iron and desoldering pump, desolder the reset switch from the board.
    • For more information, see this guide on desoldering.
Rachel Shaw
553 Reputation
5 Guides authored
Cal Poly, Team 10-7, Livingston Fall 2016 Member of Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 1,150
