D-Link HD Wi-Fi Camera Camera Lens Replacement
  1. D-Link HD Wi-Fi Camera Camera Lens Replacement, Motherboard: step 1, image 1 of 1
    • Place the camera upwards between your thumb and first finger.
    • Tilt the camera to the best position and loosen the captive linings using a plastic opening tool.
    • Slide the top cover outwards to separate the upper section from the lower lid using the plastic opening tool.
  2. D-Link HD Wi-Fi Camera Camera Lens Replacement: step 2, image 1 of 2 D-Link HD Wi-Fi Camera Camera Lens Replacement: step 2, image 2 of 2
    • Remove the 6.0mm Phillips #00 screws that secure the back cover to the inner frame.
    • Lift the rear lid upwards using your fingers and separate it from the internal components and motherboard.
  3. D-Link HD Wi-Fi Camera Camera Lens Replacement: step 3, image 1 of 2 D-Link HD Wi-Fi Camera Camera Lens Replacement: step 3, image 2 of 2
    • Unscrew the motherboard from the frame. There are 3 Phillips #00 5.0mm screws holding it in place.
    • Then (gently!) remove the motherboard and the lens with your fingers.
  4. D-Link HD Wi-Fi Camera Camera Lens Replacement, Camera Lens: step 4, image 1 of 2 D-Link HD Wi-Fi Camera Camera Lens Replacement, Camera Lens: step 4, image 2 of 2
    • Make sure your hands are dry and you are working in a dry area. To prevent damage, do not touch the lens.
    • There are two Phillips #00 6.0mm screws keeping the camera in place. Remove the screws first.
    • Gently unplug the camera from the motherboard, and remove the camera.
Morgen Jaques
533 Reputation
5 Guides authored
One Comment
How do I get hold of a replacement lens? Can’t seem to find anyone selling them. Need one for a DCS-2670L
Paul Williams - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 20
All Time: 1,120
