DBPOWER T20 Disassembly
  1. DBPOWER T20 Disassembly, DBPOWER T20 Disassembly: step 1, image 1 of 1
    • Flip the device and lay flat.
  2. DBPOWER T20 Disassembly: step 2, image 1 of 1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Disassembly: step 3, image 1 of 3 DBPOWER T20 Disassembly: step 3, image 2 of 3 DBPOWER T20 Disassembly: step 3, image 3 of 3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Disassembly: step 4, image 1 of 1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Disassembly: step 5, image 1 of 2 DBPOWER T20 Disassembly: step 5, image 2 of 2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Disassembly: step 6, image 1 of 3 DBPOWER T20 Disassembly: step 6, image 2 of 3 DBPOWER T20 Disassembly: step 6, image 3 of 3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Disassembly: step 7, image 1 of 2 DBPOWER T20 Disassembly: step 7, image 2 of 2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Disassembly: step 8, image 1 of 1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Disassembly: step 9, image 1 of 2 DBPOWER T20 Disassembly: step 9, image 2 of 2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Disassembly: step 10, image 1 of 2 DBPOWER T20 Disassembly: step 10, image 2 of 2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
Andrea Espinosa
521 Reputation
3 Guides authored
USF Tampa, Team S16-G2, Boczar Spring 2018 Member of USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 Members
5 Guides authored
4 Guide Comments
Anyone find a bulb for this thing? And/or know what else (or a quick fix) would fix a dark or burn mark on the image?
jcr4130 - Reply
haing the same issue tried to call a electronics repair place to see if the could order a new polarizing lens for me and they said they could not unless they were the ones that did the repair
derek_russell82308 -
Really? Well, crap
KweenBeeTX -
How are the lenses supposed to sit in the hompow t20 mini projector
Joseph Duffey - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 30
All Time: 3,254
