DBPOWER T20 Lens Replacement
  1. DBPOWER T20 Lens Replacement, DBPOWER T20 Disassembly: step 1, image 1 of 1
    • Flip the device and lay flat.
  2. DBPOWER T20 Lens Replacement: step 2, image 1 of 1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Lens Replacement: step 3, image 1 of 3 DBPOWER T20 Lens Replacement: step 3, image 2 of 3 DBPOWER T20 Lens Replacement: step 3, image 3 of 3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Lens Replacement: step 4, image 1 of 1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Lens Replacement: step 5, image 1 of 2 DBPOWER T20 Lens Replacement: step 5, image 2 of 2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Lens Replacement: step 6, image 1 of 3 DBPOWER T20 Lens Replacement: step 6, image 2 of 3 DBPOWER T20 Lens Replacement: step 6, image 3 of 3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Lens Replacement: step 7, image 1 of 2 DBPOWER T20 Lens Replacement: step 7, image 2 of 2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Lens Replacement: step 8, image 1 of 1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Lens Replacement: step 9, image 1 of 2 DBPOWER T20 Lens Replacement: step 9, image 2 of 2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Lens Replacement: step 10, image 1 of 2 DBPOWER T20 Lens Replacement: step 10, image 2 of 2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Lens Replacement, Lens: step 11, image 1 of 1
    • The lamp does not need to be removed for this step to be preformed.
  12. DBPOWER T20 Lens Replacement: step 12, image 1 of 1
    • Detach the keystone adjuster from the lens housing.
    • Lens is on a hinge so it should lift off easily, if it doesn't, adjust by swaying it forward or backward.
  13. DBPOWER T20 Lens Replacement: step 13, image 1 of 1
    • Remove the rubber foot and warranty sticker found underneath the device.
  14. DBPOWER T20 Lens Replacement: step 14, image 1 of 2 DBPOWER T20 Lens Replacement: step 14, image 2 of 2
    • Remove the two screws on the bottom of the device with a J0 screwdriver.
  15. DBPOWER T20 Lens Replacement: step 15, image 1 of 1
    • Remove the focus-adjustment ring from the lens housing.
4 other people completed this guide.
Andrea Espinosa
521 Reputation
3 Guides authored
USF Tampa, Team S16-G2, Boczar Spring 2018 Member of USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 Members
5 Guides authored
3 Guide Comments
How does the lens parts go together?
Lay - Reply
I need to know the same
Tremaine Mullins - Reply
Trying to put my lens back how to install
David Williams - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 29
All Time: 2,717
