DCC-3200 Faulty Power Cord Replacement
  1. DCC-3200 Faulty Power Cord Replacement, Faulty Power Cord: step 1, image 1 of 1
    • First, please be sure that the device is unplugged and that there is no water in the reservoir.
    • Check the power cord for frays or cracks.
  2. DCC-3200 Faulty Power Cord Replacement: step 2, image 1 of 1
    • If the cord appears fine, please flip the device upside-down and unscrew the 4 screws on the bottom.
  3. DCC-3200 Faulty Power Cord Replacement: step 3, image 1 of 1
    • Remove the bottom panel and unclip the power cord from the panel.
  4. DCC-3200 Faulty Power Cord Replacement: step 4, image 1 of 1
    • With the front facing towards you upside down, to the top left of the circular hotplate is a beige circuit board with two screws on either side holding it in. Please unscrew them.
  5. DCC-3200 Faulty Power Cord Replacement: step 5, image 1 of 1
    • Carefully remove the circuit board and unplug the gray ribbon wire that is plugged into it.
  6. DCC-3200 Faulty Power Cord Replacement: step 6, image 1 of 1
    • Check to see if the power cord is connected properly to the circuit board.
  7. DCC-3200 Faulty Power Cord Replacement: step 7, image 1 of 1
    • Strip the wire and twist with the other or solder it back on.
Hamad Khan
385 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 2,017
