DDX/ Copperhead Hotend Installation
  1. DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: step 1, image 1 of 3 DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: step 1, image 2 of 3 DDX/ Copperhead Hotend Installation, Prepare Copperhead™ Adapter: step 1, image 3 of 3
    • Use 2x 2.5x6mm screws supplied with the Copperhead™ hotend.
    • Insert them in the mounting holes.
  2. DDX/ Copperhead Hotend Installation, Attach Adapter To Hotend: step 2, image 1 of 2 DDX/ Copperhead Hotend Installation, Attach Adapter To Hotend: step 2, image 2 of 2
    • Attach Adapter and hotend.
    • New lineNotice the orientation of the Adapter and Hot Block.
    • These indented marks should be oriented towards the front of the DDX.
    • The fixation screws that attach the DDX to the carriage plate will enter through them.
  3. DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: step 3, image 1 of 3 DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: step 3, image 2 of 3 DDX/ Copperhead Hotend Installation, Prepare PTFE Tube: step 3, image 3 of 3
    • Insert the Capricorn tube inside the Adapter and hotend.
    • Push hard until it hits the bottom.
    • Download the PTFE cutting fixture
  4. DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: step 4, image 1 of 3 DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: step 4, image 2 of 3 DDX/ Copperhead Hotend Installation, Cut PTFE Tube To Spec: step 4, image 3 of 3
    • Insert the Capricorn tube in the cutting fixture
    • Drive it until it fits the Adapter
    • Pressing all together use the hobby knife to cut the tube straight.
    • At the end, the Capricorn should stand out about 5mm.
  5. DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: step 5, image 1 of 3 DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: step 5, image 2 of 3 DDX/ Copperhead Hotend Installation, Insert Copperhead™ Into DDX: step 5, image 3 of 3
    • Spread the housing apart from 2 to 3mm
    • Insert the Copperhead™ in at an angle.
    • Push it until the mounting holes align.
  6. DDX/ Copperhead Hotend Installation, Close DDX 1/2: step 6, image 1 of 3 DDX/ Copperhead Hotend Installation, Close DDX 1/2: step 6, image 2 of 3 DDX/ Copperhead Hotend Installation, Close DDX 1/2: step 6, image 3 of 3
    • If when clamping the DDX the gears collide:
    • Release the thumbscrew.
    • Open the hinge.
    • Clamp both halves while rotating the main gear back and forth.
  7. DDX/ Copperhead Hotend Installation, Close DDX 2/2: step 7, image 1 of 3 DDX/ Copperhead Hotend Installation, Close DDX 2/2: step 7, image 2 of 3 DDX/ Copperhead Hotend Installation, Close DDX 2/2: step 7, image 3 of 3
    • When the DDX closes down verify the mounting holes alignment.
    • Screw the back screws to close it.
Tiny Machines 3D
3,019 Reputation
14 Guides authored
Tiny Machines 3D Member of Tiny Machines 3D
Community
5 Members
41 Guides authored
2 Guide Comments
where do i get the cutting fixture
Sarbartha Sengupta - Reply
Thanks for your questions. We’ve added a link to step 3.
Tiny Machines 3D -
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 246
