DJI Mavic Mini GPS Replacement
  1. DJI Mavic Mini GPS Replacement, Battery: step 1, image 1 of 2 DJI Mavic Mini GPS Replacement, Battery: step 1, image 2 of 2
    • Orient the DJI Mavic Mini so that the camera faces away.
    • Use your finger to depress the lip on the panel until the lid becomes ajar.
    • Flip the panel up to expose the battery module.
  2. DJI Mavic Mini GPS Replacement: step 2, image 1 of 2 DJI Mavic Mini GPS Replacement: step 2, image 2 of 2
    • Depress the locking mechanism on the battery module to release the lock.
    • Pull the battery straight out of the casing.
  3. DJI Mavic Mini GPS Replacement: step 3, image 1 of 2 DJI Mavic Mini GPS Replacement: step 3, image 2 of 2
    • Check the battery pins on the DJI Drone for corrosion or warping. If either of these conditions are present, replacing the battery module may not help resolve the issue at hand.
    • Check the pin receptacles on the battery module for blockages.
    • Insert a new battery into the casing. Ensure that all connections are clean, unobstructed, and straight.
  4. DJI Mavic Mini GPS Replacement, GPS: step 4, image 1 of 2 DJI Mavic Mini GPS Replacement, GPS: step 4, image 2 of 2
    • Put your fingers against edge of the top case and begin undoing the connections at the edges first, then proceed to pry it open.
    • Alternatively, you may insert the iFixit opening tool between the top and bottom case first, and work your way around the perimeter to detach the top case.
  5. DJI Mavic Mini GPS Replacement: step 5, image 1 of 1
    • With the internals exposed, locate the GPS board; this is the middle board component with a colored square located near the middle of the drone.
  6. DJI Mavic Mini GPS Replacement: step 6, image 1 of 3 DJI Mavic Mini GPS Replacement: step 6, image 2 of 3 DJI Mavic Mini GPS Replacement: step 6, image 3 of 3
    • Remove the three 1.0 mm screws that form a triangle around the GPS board using the JIS #000 screwdriver.
    • Flip the GPS module over gently. Be mindful that it is attached to the device with a connector still.
  7. DJI Mavic Mini GPS Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Use the ESD Safe Tweezers Blunt Nose tool to break apart the superglue connecting the cable to the GPS.
    • Repeat this for the superglue on the other side.
    • Detach the press-fit connecter from the GPS.
  8. DJI Mavic Mini GPS Replacement: step 8, image 1 of 1
    • Remove the GPS from the drone.
2 other people completed this guide.
Edward Ng
175 Reputation
1 Guide authored
Clemson, Team 1-2, Hunter Spring 2022 Member of Clemson, Team 1-2, Hunter Spring 2022
CLEM-HUNTER-S22S1G2
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 62
All Time: 2,253
