DJI Mavic Mini Propellers Replacement
  1. DJI Mavic Mini Propellers Replacement, Propellers: step 1, image 1 of 3 DJI Mavic Mini Propellers Replacement, Propellers: step 1, image 2 of 3 DJI Mavic Mini Propellers Replacement, Propellers: step 1, image 3 of 3
    • Place the DJI Mavic Mini on a flat surface with the props oriented upwards.
    • For ease of access place the prop arms in the "open" position.
  2. DJI Mavic Mini Propellers Replacement: step 2, image 1 of 3 DJI Mavic Mini Propellers Replacement: step 2, image 2 of 3 DJI Mavic Mini Propellers Replacement: step 2, image 3 of 3
    • Remove the 2.4 mm J000 screw from the damaged propeller.
    • When removing the screws, you may need to apply some pressure to the swivel mount that holds the propellers.
    • Remove the damaged propellers.
  3. DJI Mavic Mini Propellers Replacement: step 3, image 1 of 2 DJI Mavic Mini Propellers Replacement: step 3, image 2 of 2
    • Keep the 2.4 mm J000 screw from the damaged propeller to use again when fastening on the replacement.
    • While one or both propellers are removed for replacement, it is recommended that you inspect the exposed swivel mount for any debris which may impact drone performance.
    • Additionally, when fastening the replacement propeller make sure that the screw is inserted into the interior hole on the swivel mount.
Chase Smith
147 Reputation
1 Guide authored
Clemson, Team 1-2, Hunter Spring 2022 Member of Clemson, Team 1-2, Hunter Spring 2022
CLEM-HUNTER-S22S1G2
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 36
All Time: 899
