DJI Mavic Pro Controller Micro USB Port Replacement
  1. DJI Mavic Pro Controller Micro USB Port Replacement, Identify broken part: step 1, image 1 of 1
    • It's easy to put the micro USB in the wrong way around (turned 180 degrees) this will break your pins and makes the controller not able to charge anymore. Check if the inside of your port is all good
  2. DJI Mavic Pro Controller Micro USB Port Replacement, Get the replacement part: step 2, image 1 of 2 DJI Mavic Pro Controller Micro USB Port Replacement, Get the replacement part: step 2, image 2 of 2
    • get the replacement part for your controller where the Micro Usb is connected to
  3. DJI Mavic Pro Controller Micro USB Port Replacement, Get started: step 3, image 1 of 1
    • Get your tools, controller and part in place to get started
  4. DJI Mavic Pro Controller Micro USB Port Replacement, Remove Joystick: step 4, image 1 of 1
    • First remove the joystick. You can just pull this out. In my case I already lost it 2 years ago. Easy!
  5. DJI Mavic Pro Controller Micro USB Port Replacement, Unscrew 2 bottom caps: step 5, image 1 of 2 DJI Mavic Pro Controller Micro USB Port Replacement, Unscrew 2 bottom caps: step 5, image 2 of 2
    • Unscrew the two screws on the bottom using a torx 6
  6. DJI Mavic Pro Controller Micro USB Port Replacement, Open the cover: step 6, image 1 of 1
    • This was the most complex step. Once you remove the 2 screws from the previous step you can open up the bottom. This is a tough piece of plastic clicked into the sides. It required some fiddling and squeezing. It looks like you will break the plastic. But you won't. Plastic is precious you know
  7. DJI Mavic Pro Controller Micro USB Port Replacement, Remove the front panel: step 7, image 1 of 3 DJI Mavic Pro Controller Micro USB Port Replacement, Remove the front panel: step 7, image 2 of 3 DJI Mavic Pro Controller Micro USB Port Replacement, Remove the front panel: step 7, image 3 of 3
    • First remove the 2 phillips screws on at the top corners. There are 2 places where the front panels locks on the controller. (those big round things) Just pull it of there and you can open up the controller and remove the panel
  8. DJI Mavic Pro Controller Micro USB Port Replacement, Open the controller: step 8, image 1 of 2 DJI Mavic Pro Controller Micro USB Port Replacement, Open the controller: step 8, image 2 of 2
    • Now the controller is open, you can see the part you need to replace, just a few steps away
  9. DJI Mavic Pro Controller Micro USB Port Replacement, Remove the keyboard cable: step 9, image 1 of 1
    • open up the tiny lever and you can remove the data cable of the keyboard
  10. DJI Mavic Pro Controller Micro USB Port Replacement, remove final 2 screw: step 10, image 1 of 2 DJI Mavic Pro Controller Micro USB Port Replacement, remove final 2 screw: step 10, image 2 of 2
    • There are.2 screws that connect the part you want to replace. Unscrew and you can remove it
  11. DJI Mavic Pro Controller Micro USB Port Replacement, Replace the part and check: step 11, image 1 of 1
    • You can now replace the part, but before we put everything back together make sure it works (charges! :)
  12. DJI Mavic Pro Controller Micro USB Port Replacement, Future Upgrade: step 12, image 1 of 1
    • My part broke because I put the cable in wrong way around, apparently this is a common problem from this controller. Makes me wonder why it usually does not go wrong. Anyway, to prevent this in the future i've marked how the Micro USB cable should go in. Flat part down!
5 other people completed this guide.
Dave Hakkens
1,024 Reputation
3 Guides authored
9 Comments
Thank you for sharing your experience and knowledge. :-)
Fernando Kojin - Reply
How and where do you get this replacement part from DJI ?
I have the exact same issue
Romain Rosset - Reply
I see you didn’t respond back to Romain and I have the same question now, after reviewing your incredible detailed example of replacement. Same reason, obviously, I put the connector in upside down and broke it… thank you, hope you respond soon
Pops Eagles - Reply
Got it somewhere from ebay
Dave Hakkens -
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 38
All Time: 6,368
