DJI Mavic Pro Propeller Replacement
  1. DJI Mavic Pro Propeller Replacement, Propellers: step 1, image 1 of 3 DJI Mavic Pro Propeller Replacement, Propellers: step 1, image 2 of 3 DJI Mavic Pro Propeller Replacement, Propellers: step 1, image 3 of 3
    • Unfold your Dji Mavic Pro Drone.
  2. DJI Mavic Pro Propeller Replacement: step 2, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 2, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 2, image 3 of 3
    • Push down slightly on the propeller you want to remove.
  3. DJI Mavic Pro Propeller Replacement: step 3, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 3, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 3, image 3 of 3
    • There are 2 types of propellers on a DJI Mavic Pro drone: 1 with a white circle outline (shown in the image) and 1 without.
    • If the propeller you want to remove has a white outline like shown in the image, then turn the propeller counterclockwise to unlock its position.
  4. DJI Mavic Pro Propeller Replacement: step 4, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 4, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 4, image 3 of 3
    • If the propeller you want to remove DOES NOT have a white outline, then turn the propeller clockwise to unlock its position.
  5. DJI Mavic Pro Propeller Replacement: step 5, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 5, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 5, image 3 of 3
    • Pull up the propeller to remove it.
  6. DJI Mavic Pro Propeller Replacement: step 6, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 6, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 6, image 3 of 3
    • To replace the propellers, check to match the propellers with the arm of the drone.
    • The propeller with a white circle will have to be placed on the arm of the drone with a white outline and the propeller without the white circle will be placed on the arm of the drone without the white outline.
  7. DJI Mavic Pro Propeller Replacement: step 7, image 1 of 3 DJI Mavic Pro Propeller Replacement: step 7, image 2 of 3 DJI Mavic Pro Propeller Replacement: step 7, image 3 of 3
    • Align the parts outlined with red with the holes on the arm of the drone outlined by the red.
    • Push the propeller down.
  8. DJI Mavic Pro Propeller Replacement: step 8, image 1 of 2 DJI Mavic Pro Propeller Replacement: step 8, image 2 of 2
    • If the propeller has NO white mark (circle) then turn the propeller counterclockwise to lock its position.
    • If the propeller has a white mark (circle) then turn the propeller clockwise to lock its position.
  9. DJI Mavic Pro Propeller Replacement: step 9, image 1 of 2 DJI Mavic Pro Propeller Replacement: step 9, image 2 of 2
    • Check to see if the propeller is properly locked into place by slightly pulling it up.
    • If it is locked, then you can safely fly your drone.
Finish Line
0 Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 109
All Time: 4,526
