DJI Mavic Pro Top Case Removal
Video Overview
  1. DJI Mavic Pro Top Case Removal, Remove Battery: step 1, image 1 of 3 DJI Mavic Pro Top Case Removal, Remove Battery: step 1, image 2 of 3 DJI Mavic Pro Top Case Removal, Remove Battery: step 1, image 3 of 3
    • To start removing screws, you must first remove the battery, by squeezing the sides of the battery, as shown in the photos, and lighting it up and away from the drone.
  2. DJI Mavic Pro Top Case Removal, Remove screws under the battery: step 2, image 1 of 1
    • There are 6 screws on the top of the drone. Four of them are located under the battery, and the other two are right on the back end of the drone. They are all 5.8mm long, and have a 1.5mm hex head, I, however, found that they are easier to remove using a T6H Torx bit.
  3. DJI Mavic Pro Top Case Removal, Remove Screws on the Bottom: step 3, image 1 of 2 DJI Mavic Pro Top Case Removal, Remove Screws on the Bottom: step 3, image 2 of 2
    • Now, flip over the drone, and orient it with the camera facing you. You should remove the camera/gimbal cover at this point, but its probably a good idea to leave the gimbal brace in place.
    • Remove the four closest screws circled in red. The ones closest to the front are 5.8mm long, with a 2mm diameter, while the ones closer to the rear of the drone are 4.8mm long, with a 1.5mm diameter. Be careful not to confuse these screws when reassembling the drone.
  4. DJI Mavic Pro Top Case Removal, Remove the Plastic Covers That Cover the Front Arm Hinge: step 4, image 1 of 3 DJI Mavic Pro Top Case Removal, Remove the Plastic Covers That Cover the Front Arm Hinge: step 4, image 2 of 3 DJI Mavic Pro Top Case Removal, Remove the Plastic Covers That Cover the Front Arm Hinge: step 4, image 3 of 3
    • There are screws under these covers, which need to be removed, as they hold the top plate in place. to do this, you need to take something sharp, a flat edge hobby knife, for example, and pop the cover up out of place in the front end, and then work your way around to the rear of them, once you get to the back, it should pop right off.
    • You will need to do this on both the left and right side of the drone.
    • My apologies, the wrong area is in focus in these pictures, but I feel that they can still serve their purpose adequately.
  5. DJI Mavic Pro Top Case Removal, Remove the Screws Under the Front Arm Covers: step 5, image 1 of 1
    • There are two 1.5mm hex screws, these are 5.8mm long, with a 2mm diameter. These are thicker than the screws holding the covers down, because those screws are only holding the covers down, while the screws under it are holding the top cover down. Take note of this during reassembly.
  6. DJI Mavic Pro Top Case Removal, Pry up Rear Case: step 6, image 1 of 3 DJI Mavic Pro Top Case Removal, Pry up Rear Case: step 6, image 2 of 3 DJI Mavic Pro Top Case Removal, Pry up Rear Case: step 6, image 3 of 3
    • First, turn the drone over, so it is right side up, and facing away from you. Now, use a metal spudger to pry open the rear end of the case. Be careful not to pull too far up, as there is still a cable which is connecting the two pieces.
    • Slide the spudger down the length of each side, undoing all the clips along the way, stop 1-2 cm before the ending of the battery cradle.
  7. DJI Mavic Pro Top Case Removal, Disconnect GPS From Logic Board: step 7, image 1 of 3 DJI Mavic Pro Top Case Removal, Disconnect GPS From Logic Board: step 7, image 2 of 3 DJI Mavic Pro Top Case Removal, Disconnect GPS From Logic Board: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Gently lift up the rear of the top case .5-1mm, and insert a pair of tweezers, grab the black cloth shielded cable connecting the top and bottom, and gently pull it up and away from the bottom board. The rear should lift freely up from the case 2-3mm.
  8. DJI Mavic Pro Top Case Removal, Remove Front End of Top Cover: step 8, image 1 of 1
    • Insert your metal spudger in between the top and bottom case on both the left and right sides of the drone, as shown in the photo. Pry up gently until it is free.
  9. DJI Mavic Pro Top Case Removal, Unhinge Front Edge of Top Cover: step 9, image 1 of 2 DJI Mavic Pro Top Case Removal, Unhinge Front Edge of Top Cover: step 9, image 2 of 2
    • This part is tricky. There are four clips folding the front edge in place. Half are facing one direction and half are facing he opposite direction. Be gentle and careful when disengaging them. The photos here, show the locations and directions of the clips.
28 other people completed this guide.
Andrew
929 Reputation
1 Guide authored
Digital-Hospital Member of Digital-Hospital
Business
1 Member
1 Guide authored
3 Comments
I had a crash .a small crash. looking down on the drone it would be the rear view and is the left rear folding arm ,the stop for this arm when unfolded the crash broke the stop for the left rear arm . I have used a glue to reset the stop how ever I think this is only a very temp fix I think I will have to replace the hole under structure case for the drone . sorry my name is David from Saskatchewan . Canada
David Hall - Reply
I had a crash .a small crash. looking down on the drone it would be the rear view and is the left rear folding arm ,the stop for this arm when unfolded the crash broke the stop for the left rear arm . I have used a glue to reset the stop how ever I think this is only a very temp fix I think I will have to replace the hole under structure case for the drone . sorry my name is David from Saskatchewan . Canada now you want another comment and I have nothing to comment about except this
David Hall - Reply
If you are replacing the upper shell (like I just did due to a tree branch poking a hole through it - ouch!) then there are a couple more steps not included in this guide. You need to remove a small metal plate held on with two Phillips head screws, then take out the logic board. The logic board and metal plate then need to be fitted to the new upper shell. I also transferred the big sticker in the bottom of the battery housing from the old shell to the new one, as this contains a bunch of information about the drone (including serial number etc).
I should just clarify that I was working on a Mavic Pro, but I’m assuming the Mavic 2 has a similar setup internally.
Aaron Doty -
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 53
All Time: 16,692
