DJI Mini 2 Drone Body Replacement
  1. DJI Mini 2 Drone Body Replacement, Battery: step 1, image 1 of 2 DJI Mini 2 Drone Body Replacement, Battery: step 1, image 2 of 2
    • Face the DJI Mini 2 away from you so that you are looking at the charging ports.
    • Use your finger to open up the back panel.
  2. DJI Mini 2 Drone Body Replacement: step 2, image 1 of 2 DJI Mini 2 Drone Body Replacement: step 2, image 2 of 2
    • Pinch the locking mechanism on the battery to release the lock.
    • Pull the battery straight out of the compartment.
  3. DJI Mini 2 Drone Body Replacement, Drone Body: step 3, image 1 of 2 DJI Mini 2 Drone Body Replacement, Drone Body: step 3, image 2 of 2
    • Unfold the wings of the drone.
    • Place the drone upside down on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
  4. DJI Mini 2 Drone Body Replacement: step 4, image 1 of 2 DJI Mini 2 Drone Body Replacement: step 4, image 2 of 2
    • Remove the four 5 mm J000 screws near each propeller arm.
  5. DJI Mini 2 Drone Body Replacement: step 5, image 1 of 3 DJI Mini 2 Drone Body Replacement: step 5, image 2 of 3 DJI Mini 2 Drone Body Replacement: step 5, image 3 of 3
    • Flip the drone back over.
    • Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams.
  6. DJI Mini 2 Drone Body Replacement: step 6, image 1 of 2 DJI Mini 2 Drone Body Replacement: step 6, image 2 of 2
    • Remove the two 5 mm J000 screws located in the battery hatch and near the ports on the back of the drone.
  7. DJI Mini 2 Drone Body Replacement: step 7, image 1 of 2 DJI Mini 2 Drone Body Replacement: step 7, image 2 of 2
    • Flip the drone over again.
    • Pry off the bottom panel of the drone using the opening tools and your fingers.
6 other people completed this guide.
Jacob Matos
1,083 Reputation
4 Guides authored
2 Comments
Where to buy a new drone body ?
Loïc Sarda - Reply
Same Q. Where to buy drone body? Please email me. Thanks
Ruud - Reply
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 177
All Time: 5,269
