DJI Mini 2 Propeller Blades Replacement
  1. DJI Mini 2 Propeller Blades Replacement, Propeller Blades: step 1, image 1 of 1
    • Open up the propeller arms to make it easier to access the propeller blades.
    • Then, place the drone on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
  2. DJI Mini 2 Propeller Blades Replacement: step 2, image 1 of 2 DJI Mini 2 Propeller Blades Replacement: step 2, image 2 of 2
    • Remove the 7mm J000 head screw attaching the blade to the motor.
    • Some pressure may be needed to successfully unscrew the screw.
    • Remove the propeller blades.
Attached Documents
Jacob Matos
1,083 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 62
All Time: 1,820
