This teardown is not a repair guide. To repair your DJI Mini 3, use our service manual.
  1. DJI Mini 3 Chip ID, Drone Main Board Side A: step 1, image 1 of 2 DJI Mini 3 Chip ID, Drone Main Board Side A: step 1, image 2 of 2
    • Ambarella H22-A0-RH H22 quad-core video SoC
    • Kingston D1216ECMDXGME-U 256 MB DDR3L SDRAM memory
    • HDSC HC32F460JEUA 32-bit ARM Cortex-M4 microcontroller
    • Qualcomm SMB2352–207 dual-cell Li-ion battery charger
    • Monolithic Power Systems MP6507GQ stepper motor driver w/ MOSFETs
    • Silergy SY6280AAC power distribution switch
    • OmniVision WAS7222Q 480 Mbps DPDT analog switch
  2. DJI Mini 3 Chip ID: step 2, image 1 of 1
    • Texas Instruments TLV75901P 1 A / adj. LDO regulator
    • OmniVision WL2836D12 300 mA / 1.2 V LDO regulator
    • OmniVision WL2836D18 300 mA / 1.8 V LDO regulator
    • OmniVision WL2848D18 300 mA / 1.8 V LDO regulator
    • OmniVision WL2836D25 300 mA / 2.5 V LDO regulator
    • Nexperia 74LVC2T45 dual supply translating transceiver
    • Nexperia 74LVC1G08 single 2-input AND gate
  3. DJI Mini 3 Chip ID: step 3, image 1 of 1
    • Yangjie Electronic Technology YJQ1216A P-Channel MOSFET
  4. DJI Mini 3 Chip ID, Drone Main Board Side A - Radio: step 4, image 1 of 1
    • Possibly Leadcore S1 RF transceiver
    • Kangxi Communication Technologies KCT8247HE-1 2.4 GHz WLAN front-end module
    • Kangxi Communication Technologies KCT8576N 5 GHz WLAN front-end module
    • Likely Maxscend MXDx213 low noise amplifier
    • Likely Maxscend DPDT RF switch
    • Likely Maxscend MXD8622E SPDT RF switch
  5. DJI Mini 3 Chip ID, Drone Main Board Side B: step 5, image 1 of 2 DJI Mini 3 Chip ID, Drone Main Board Side B: step 5, image 2 of 2
    • NXP Semiconductor MIMXRT1064DVL6B i.MX single core application processor
    • Kioxia TC58NVG1S3HBAI6 256 MB NAND flash memory
    • Monolithic Power Systems MP6543HGL 3-phase power stage
    • Silicon Content Technology SCT2260A 6 A synchronous step-down DC-DC converter
    • Silicon Content Technology SCT2230 3 A synchronous step-down DC-DC converter
    • Monolithic Power Systems DC-DC Converter
  6. DJI Mini 3 Chip ID: step 6, image 1 of 1
    • Possibly Linearin LTP3330 300 mA / 3.0 V LDO Regulator
    • OmniVision WL2836D33 300 mA / 3.3 V LDO regulator
  7. DJI Mini 3 Chip ID, Drone Main Board Side B - Radio: step 7, image 1 of 1
    • Synaptics SYN43456PXKUBG single-chip 5G WiFi 802.11ac w/ Bluetooth 5 & FM receiver
  8. DJI Mini 3 Chip ID, Distance Sensor Board Side A: step 8, image 1 of 2 DJI Mini 3 Chip ID, Distance Sensor Board Side A: step 8, image 2 of 2
  9. DJI Mini 3 Chip ID, Distance Sensor Board Side B: step 9, image 1 of 2 DJI Mini 3 Chip ID, Distance Sensor Board Side B: step 9, image 2 of 2
    • Texas Instruments OPT3101 distance sensor analog front-end
    • SG Micro SGM2036-1.2 300 mA / 1.2 V LDO regulator
    • SG Micro SGM2036-1.8 300 mA / 1.8 V LDO regulator
    • SG Micro SGM2036-2.8 300 mA / 2.8 V LDO regulator
  10. DJI Mini 3 Chip ID, GNSS Receiver Board Side A: step 10, image 1 of 2 DJI Mini 3 Chip ID, GNSS Receiver Board Side A: step 10, image 2 of 2
    • TDK-InvenSense ICM-40609-D 6-axis MEMS accelerometer & gyroscope
    • Goertek SPL06-001 pressure and temperature sensor
  11. DJI Mini 3 Chip ID, GNSS Receiver Board Side B: step 11, image 1 of 2 DJI Mini 3 Chip ID, GNSS Receiver Board Side B: step 11, image 2 of 2
    • u-blox UBX-M10050-KB GNSS receiver
    • Maxscend MXDLN16TP GNSS low noise amplifier
  12. DJI Mini 3 Chip ID, GNSS Receiver Board Side B - Filters: step 12, image 1 of 1
  13. DJI Mini 3 Chip ID, Motor Controller Board Side A: step 13, image 1 of 2 DJI Mini 3 Chip ID, Motor Controller Board Side A: step 13, image 2 of 2
    • Texas Instruments DRV8328B 3-phase BLDC gate driver
  14. DJI Mini 3 Chip ID, Motor Controller Board Side B: step 14, image 1 of 2 DJI Mini 3 Chip ID, Motor Controller Board Side B: step 14, image 2 of 2
    • Spintrol SPC1168APE48 32-bit ARM Cortex-M4 microcontroller
    • Vergiga VS3622DB 30 V dual N-channel MOSFET
  15. DJI Mini 3 Chip ID, Sensor Flex Side A: step 15, image 1 of 2 DJI Mini 3 Chip ID, Sensor Flex Side A: step 15, image 2 of 2
  16. DJI Mini 3 Chip ID, Battery Board Side A: step 16, image 1 of 2 DJI Mini 3 Chip ID, Battery Board Side A: step 16, image 2 of 2
    • Texas Instruments BQ9003 battery fuel gauge (likely)
    • Advanced Power Electronics Corp. AP3N1R8MT 30 V N-channel MOSFET
  17. DJI Mini 3 Chip ID, Block Diagram: step 17, image 1 of 2 DJI Mini 3 Chip ID, Block Diagram: step 17, image 2 of 2
    • Predicted block diagram primarily based on available datasheets and observed implementation in product.
CChin
7,157 Reputation
7 Guides authored
8 Guide Comments
Perfect sharing
BEKTAŞ KANTEMİR - Reply Share
It's great. Thank you. Did you also disassemble the dji mini4 or mini4 pro like that?
albert - Reply Share
Hi. Do you have high resolution on main board? I had my drone played submarine, so I had to clean the board. Few resistors located at the left of LEDs brushed out :(
Vitaliy K - Reply Share
If I was looking to reset the binding application but I'll be looking at the slc nand 256 flash memory all I need to do is short this chip out to flash it but I'll take out the recent bound
controller
Kiss Myass - Reply Share
sounds a little over optimistic - 99,9% chance the data is encrypted.
Paul, Ehrlich - Share
Past 24 Hours: 8
Past 7 Days: 84
Past 30 Days: 408
All Time: 10,261
