DJI Phantom 3 Advanced Cover Replacement
  1. DJI Phantom 3 Advanced Cover Replacement, Battery: step 1, image 1 of 2 DJI Phantom 3 Advanced Cover Replacement, Battery: step 1, image 2 of 2
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Cover Replacement: step 2, image 1 of 2 DJI Phantom 3 Advanced Cover Replacement: step 2, image 2 of 2
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Cover Replacement, Cover: step 3, image 1 of 1
    • Turn the Phantom 3 Advanced upside down.
  4. DJI Phantom 3 Advanced Cover Replacement: step 4, image 1 of 1
    • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
    • There is one screw per arm, located at the tip of the arm.
  5. DJI Phantom 3 Advanced Cover Replacement: step 5, image 1 of 2 DJI Phantom 3 Advanced Cover Replacement: step 5, image 2 of 2
    • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
    • There are two 5mm screws on each arm.
  6. DJI Phantom 3 Advanced Cover Replacement: step 6, image 1 of 2 DJI Phantom 3 Advanced Cover Replacement: step 6, image 2 of 2
    • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
    • There is one screw on each arm located near the landing gear.
  7. DJI Phantom 3 Advanced Cover Replacement: step 7, image 1 of 3 DJI Phantom 3 Advanced Cover Replacement: step 7, image 2 of 3 DJI Phantom 3 Advanced Cover Replacement: step 7, image 3 of 3
    • Carefully flip the phantom back over with the motors facing up.
    • Peel back the silver stickers from the seam in the cover.
    • Using a plastic spudger, slowly separate the two halves of the plastic shell.
    • This step requires some force, and the plastic will click loudly as the shell separates.
    • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
  8. DJI Phantom 3 Advanced Cover Replacement: step 8, image 1 of 3 DJI Phantom 3 Advanced Cover Replacement: step 8, image 2 of 3 DJI Phantom 3 Advanced Cover Replacement: step 8, image 3 of 3
    • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
    • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
    • Press the tab on the side of the connector and pull up on the cable.
    • Continue to remove the shell the rest of the way.
11 other people completed this guide.
Robert Comstock
433 Reputation
2 Guides authored
Cal Poly, Team 10-2, Livingston Fall 2016 Member of Cal Poly, Team 10-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G2
3 Members
12 Guides authored
3 Guide Comments
Great Job Robert! Even the “Phantom Pilots Forum” had no recent recommendations for a disassembly manual, as DJI likes to “Fixit” themselves!
Michael Steinbrecher - Reply Share
Excellent detailed instructions. Having pictures on procedure makes it idiot proof.
Bolo - Reply Share
Does this also include the phantom 3 professional too? My understanding is that the only differences between them is the battery charger and the pro is 4k recording vs 1080p.
John D - Reply Share
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 54
All Time: 5,576
