Introduction
If the motors are intact but not starting, then there is a problem with the electronic speed controller. Use this guide to replace your damaged electronic speed controller.
Use your finger tips to pinch the damaged propeller.
Twist the propeller counterclockwise and pull up to remove.
Remove the two 4 mm screws using the JIS #000 bit.
Flip the metal bracket to the right and slide up.
Desolder the motor and LED wires on both sides of the board. For general soldering information, visit this Soldering Technique Guide.
2 other people completed this guide.
