DJI Phantom Battery Replacement
  1. DJI Phantom Battery Replacement, Open the Battery Compartment: step 1, image 1 of 3 DJI Phantom Battery Replacement, Open the Battery Compartment: step 1, image 2 of 3 DJI Phantom Battery Replacement, Open the Battery Compartment: step 1, image 3 of 3
    • Press down on battery door release tab to flip the battery door open.
  2. DJI Phantom Battery Replacement, Remove the Battery: step 2, image 1 of 3 DJI Phantom Battery Replacement, Remove the Battery: step 2, image 2 of 3 DJI Phantom Battery Replacement, Remove the Battery: step 2, image 3 of 3
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. DJI Phantom Battery Replacement, Disconnect the Battery: step 3, image 1 of 2 DJI Phantom Battery Replacement, Disconnect the Battery: step 3, image 2 of 2
    • Pull the two halves of the XT60 power connector apart.
    • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
David Hoyt
4,053 Reputation
41 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 52
All Time: 2,905
