DJI Phantom Propeller Replacement
  1. DJI Phantom Propeller Replacement, Open the Battery Compartment: step 1, image 1 of 3 DJI Phantom Propeller Replacement, Open the Battery Compartment: step 1, image 2 of 3 DJI Phantom Propeller Replacement, Open the Battery Compartment: step 1, image 3 of 3
    • Press down on battery door release tab to flip the battery door open.
  2. DJI Phantom Propeller Replacement, Remove the Battery: step 2, image 1 of 3 DJI Phantom Propeller Replacement, Remove the Battery: step 2, image 2 of 3 DJI Phantom Propeller Replacement, Remove the Battery: step 2, image 3 of 3
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. DJI Phantom Propeller Replacement, Disconnect the Battery: step 3, image 1 of 2 DJI Phantom Propeller Replacement, Disconnect the Battery: step 3, image 2 of 2
    • Pull the two halves of the XT60 power connector apart.
    • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
  4. DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: step 4, image 1 of 2 DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: step 4, image 2 of 2
    • Silver-topped propeller collets unscrew counter-clockwise
    • Black-topped propeller collets unscrew clockwise
  5. DJI Phantom Propeller Replacement, Unscrewing Silver Collets: step 5, image 1 of 3 DJI Phantom Propeller Replacement, Unscrewing Silver Collets: step 5, image 2 of 3 DJI Phantom Propeller Replacement, Unscrewing Silver Collets: step 5, image 3 of 3
    • For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
    • Once free, unscrew and remove the collet.
  6. DJI Phantom Propeller Replacement, Unscrewing Black Collets: step 6, image 1 of 3 DJI Phantom Propeller Replacement, Unscrewing Black Collets: step 6, image 2 of 3 DJI Phantom Propeller Replacement, Unscrewing Black Collets: step 6, image 3 of 3
    • For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
  7. DJI Phantom Propeller Replacement, Remove the Propeller: step 7, image 1 of 3 DJI Phantom Propeller Replacement, Remove the Propeller: step 7, image 2 of 3 DJI Phantom Propeller Replacement, Remove the Propeller: step 7, image 3 of 3
    • Gently press down the motor shaft and lift the propeller up to remove it.
David Hoyt
4,053 Reputation
41 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
61 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,421
