DJI Spark Camera Replacement
  1. DJI Spark Camera Replacement, Propellers: step 1, image 1 of 1
    • Push down on the propeller that is being replaced.
  2. DJI Spark Camera Replacement: step 2, image 1 of 2 DJI Spark Camera Replacement: step 2, image 2 of 2
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Camera Replacement, Battery: step 3, image 1 of 3 DJI Spark Camera Replacement, Battery: step 3, image 2 of 3 DJI Spark Camera Replacement, Battery: step 3, image 3 of 3
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Camera Replacement, Lid: step 4, image 1 of 3 DJI Spark Camera Replacement, Lid: step 4, image 2 of 3 DJI Spark Camera Replacement, Lid: step 4, image 3 of 3
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Camera Replacement: step 5, image 1 of 3 DJI Spark Camera Replacement: step 5, image 2 of 3 DJI Spark Camera Replacement: step 5, image 3 of 3
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Camera Replacement, Camera: step 6, image 1 of 2 DJI Spark Camera Replacement, Camera: step 6, image 2 of 2
    • Disconnect two gold antenna next to the internal GPS while removing the motherboard.
  7. DJI Spark Camera Replacement: step 7, image 1 of 3 DJI Spark Camera Replacement: step 7, image 2 of 3 DJI Spark Camera Replacement: step 7, image 3 of 3
    • Remove all the Phillips #0 screws attaching the motherboard to the drone.
    • It is the piece with both the fan and GPS module on it.
  8. DJI Spark Camera Replacement: step 8, image 1 of 2 DJI Spark Camera Replacement: step 8, image 2 of 2
    • Remove the 3.0 mm Phillips #000 screw.
  9. DJI Spark Camera Replacement: step 9, image 1 of 3 DJI Spark Camera Replacement: step 9, image 2 of 3 DJI Spark Camera Replacement: step 9, image 3 of 3
    • Remove the two Phillips #0 screws on the right and left sides.
    • Once removed, pull the front facing sensor out.
  10. DJI Spark Camera Replacement: step 10, image 1 of 3 DJI Spark Camera Replacement: step 10, image 2 of 3 DJI Spark Camera Replacement: step 10, image 3 of 3
    • Gently remove the gimbal along with the camera from the top of the device.
3 other people completed this guide.
Amelia Hagberg
463 Reputation
3 Guides authored
2 Guide Comments
Good start, but missing many steps and details.
Basil Yokarinis - Reply
I am now going to try and fix my drone. thank you so much
sebasnavarro1116 - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 40
All Time: 6,903
