DKnight MagicBox II Front Panel Assembly Replacement
  1. DKnight MagicBox II Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 2 DKnight MagicBox II Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 2 of 2
    • Using Blue Plastic opening tool pry the top rubber cover, then using the same tool remove the bottom panel
  2. DKnight MagicBox II Front Panel Assembly Replacement: step 2, image 1 of 3 DKnight MagicBox II Front Panel Assembly Replacement: step 2, image 2 of 3 DKnight MagicBox II Front Panel Assembly Replacement: step 2, image 3 of 3
    • There are four prongs on the grill in the corners, closest to the power button switch. Use the plastic opening tool to release all four prongs from the panel, and then slide the plastic opening tool along the edge of the grill to allow it to easily slide off.
  3. DKnight MagicBox II Front Panel Assembly Replacement: step 3, image 1 of 2 DKnight MagicBox II Front Panel Assembly Replacement: step 3, image 2 of 2
    • On the back panel (Opposite to the side containing the two speakers), Use the Philips head PH1 to remove all 7 screws (Screws: Head PH1 , Length 7cm).
  4. DKnight MagicBox II Front Panel Assembly Replacement: step 4, image 1 of 2 DKnight MagicBox II Front Panel Assembly Replacement: step 4, image 2 of 2
    • Pull apart the two faces to separate the back panel from the front face plate.
2 other people completed this guide.
Anthony
695 Reputation
3 Guides authored
USF Tampa, Team 17-1, Blackwell Winter 2016 Member of USF Tampa, Team 17-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G1
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,520
