DOPO 10.1 Tablet Battery Replacement
  1. DOPO 10.1 Tablet Battery Replacement, Remove Back: step 1, image 1 of 3 DOPO 10.1 Tablet Battery Replacement, Remove Back: step 1, image 2 of 3 DOPO 10.1 Tablet Battery Replacement, Remove Back: step 1, image 3 of 3
    • Take plastic opening tools, and find a spot on the back of tablet to lift the back plate. Once back is lifted enough, remove the back of the tablet carefully with fingers
  2. DOPO 10.1 Tablet Battery Replacement, Locate Battery: step 2, image 1 of 1
    • Locate battery, and examine wires connected to battery.
  3. DOPO 10.1 Tablet Battery Replacement, Remove Battery: step 3, image 1 of 3 DOPO 10.1 Tablet Battery Replacement, Remove Battery: step 3, image 2 of 3 DOPO 10.1 Tablet Battery Replacement, Remove Battery: step 3, image 3 of 3
    • Carefully remove battery without putting any strain on connected wires. The battery is held to the tablet with adhesive, so be careful not to jerk the battery when it becomes loose.
  4. DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: step 4, image 1 of 3 DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: step 4, image 2 of 3 DOPO 10.1 Tablet Battery Replacement, Disconnect Wires: step 4, image 3 of 3
    • Use a soldering iron to carefully remove wires from motherboard. Then remove battery.
Kaitlyn Hayes
414 Reputation
4 Guides authored
USF Tampa, Team 5-2, Brown Winter 2015 Member of USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 2,263
