DOPO 10.1 Tablet Screen Replacement
  1. DOPO 10.1 Tablet Screen Replacement, Screen: step 1, image 1 of 3 DOPO 10.1 Tablet Screen Replacement, Screen: step 1, image 2 of 3 DOPO 10.1 Tablet Screen Replacement, Screen: step 1, image 3 of 3
    • Remove back case of tablet by taking spudger tool to lift the back plate.
  2. DOPO 10.1 Tablet Screen Replacement: step 2, image 1 of 2 DOPO 10.1 Tablet Screen Replacement: step 2, image 2 of 2
    • With caution, unplug speakers from back case of tablet.
  3. DOPO 10.1 Tablet Screen Replacement: step 3, image 1 of 2 DOPO 10.1 Tablet Screen Replacement: step 3, image 2 of 2
    • Remove battery
    • Grab and apply light pressure to battery to release it from the back
    • Place off to the side carefully. Be sure not to disconnect cables from motherboard
  4. DOPO 10.1 Tablet Screen Replacement: step 4, image 1 of 3 DOPO 10.1 Tablet Screen Replacement: step 4, image 2 of 3 DOPO 10.1 Tablet Screen Replacement: step 4, image 3 of 3
    • Locate where the cameras are attached to motherboard
    • Now release and remove them from motherboard
    • Take camera out and place off to side
  5. DOPO 10.1 Tablet Screen Replacement: step 5, image 1 of 3 DOPO 10.1 Tablet Screen Replacement: step 5, image 2 of 3 DOPO 10.1 Tablet Screen Replacement: step 5, image 3 of 3
    • Remove motherboard
    • To do this you will have to unscrew a total of 5 .25in phillips head screws
  6. DOPO 10.1 Tablet Screen Replacement: step 6, image 1 of 3 DOPO 10.1 Tablet Screen Replacement: step 6, image 2 of 3 DOPO 10.1 Tablet Screen Replacement: step 6, image 3 of 3
    • Remove back metal piece.
    • Use plastic pry tool and go around the edges lightly and pop it off.
  7. DOPO 10.1 Tablet Screen Replacement: step 7, image 1 of 3 DOPO 10.1 Tablet Screen Replacement: step 7, image 2 of 3 DOPO 10.1 Tablet Screen Replacement: step 7, image 3 of 3
    • Using a plastic opening tool, remove the back screen pieces from the back.
  8. DOPO 10.1 Tablet Screen Replacement: step 8, image 1 of 2 DOPO 10.1 Tablet Screen Replacement: step 8, image 2 of 2
    • Using the plastic pry tool remove metal frame.
  9. DOPO 10.1 Tablet Screen Replacement: step 9, image 1 of 1
    • Take the iFixit iOpener and place it on the glue
    • This will release the glass from the plastic frame
  10. DOPO 10.1 Tablet Screen Replacement: step 10, image 1 of 1
    • Carefully remove glass. If glass is already broken use gloves to remove glass.
Michael
101 Reputation
1 Guide authored
USF Tampa, Team 5-2, Brown Winter 2015 Member of USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,788
