DOSS SoundBox Base-plate Replacement
  1. DOSS SoundBox Base-plate Replacement, Base-plate: step 1, image 1 of 3 DOSS SoundBox Base-plate Replacement, Base-plate: step 1, image 2 of 3 DOSS SoundBox Base-plate Replacement, Base-plate: step 1, image 3 of 3
    • Locate the four 3/32" screws on the bottom of your device.
    • Using a JIS #00 screwdriver, remove the four 3/32" screws.
    • After removing the screws, lift the cover off of the device.
  2. DOSS SoundBox Base-plate Replacement: step 2, image 1 of 1
    • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
    • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
    • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
  3. DOSS SoundBox Base-plate Replacement: step 3, image 1 of 1
    • Lift the base-plate off of the enclosure.
3 other people completed this guide.
1 Guide Comment
Speaker had an unusual sound. Followed guide, really easy to work on. Diagnosis broken speaker membrane.
Albi No - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 2,319
