DOSS SoundBox Speaker Replacement
  1. DOSS SoundBox Speaker Replacement, Speaker: step 1, image 1 of 2 DOSS SoundBox Speaker Replacement, Speaker: step 1, image 2 of 2
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
  2. DOSS SoundBox Speaker Replacement: step 2, image 1 of 2 DOSS SoundBox Speaker Replacement: step 2, image 2 of 2
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
  3. DOSS SoundBox Speaker Replacement: step 3, image 1 of 2 DOSS SoundBox Speaker Replacement: step 3, image 2 of 2
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
To reassemble your device, follow instructions in reverse order.
2 other people completed this guide.
1 Guide Comment
The instructions say: "The speakers are ready to be removed and replaced." But nowhere in this article am I told where to get replacement speakers. Am I just on my own for that? This website has always been so helpful in providing links for such things. :(
Janie Thurman - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 40
All Time: 3,299
