DROCON Ninja Casing Replacement
  1. DROCON Ninja Casing Replacement, Battery: step 1, image 1 of 3 DROCON Ninja Casing Replacement, Battery: step 1, image 2 of 3 DROCON Ninja Casing Replacement, Battery: step 1, image 3 of 3
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Casing Replacement, Casing: step 2, image 1 of 3 DROCON Ninja Casing Replacement, Casing: step 2, image 2 of 3 DROCON Ninja Casing Replacement, Casing: step 2, image 3 of 3
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Casing Replacement: step 3, image 1 of 2 DROCON Ninja Casing Replacement: step 3, image 2 of 2
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Casing Replacement: step 4, image 1 of 3 DROCON Ninja Casing Replacement: step 4, image 2 of 3 DROCON Ninja Casing Replacement: step 4, image 3 of 3
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 8
All Time: 255
