DWFP55130 Regulator spring Replacement
  1. DWFP55130 Regulator spring Replacement, Remove regulator knob: step 1, image 1 of 1
    • Unscrew and remove the black plastic regulator knob. While unscrewing, it will reach a stop and will keep like cannot unscrew further. Just break through the stop and unscrew to completely remove
  2. DWFP55130 Regulator spring Replacement, Remove plunger actuator: step 2, image 1 of 1
    • Use needle nose pliers to remove the plunger.
  3. DWFP55130 Regulator spring Replacement, Use Philips #3 (large) screw driver: step 3, image 1 of 1
    • Very gently unscrew the valve with a Philips #3 screwdriver. Take care not to destroy the plastic part
  4. DWFP55130 Regulator spring Replacement, Remove plastic valve: step 4, image 1 of 1
    • Use needle nose pliers to pull plastic valve assembly out
  5. DWFP55130 Regulator spring Replacement, Replace broken screw: step 5, image 1 of 1
    • Replace screw if broken. Photo is not of the original spring. The original spring had corroded and broken into 50 pieces. The spring doesn’t have to be a perfect fit, just has to hold the part in place. The original spring was approx 6mm wide, 20mm tall and 0.5mm thickness wire.
  6. DWFP55130 Regulator spring Replacement, Reassemble: step 6, image 1 of 1
    • Carry out steps in reverse to reassemble compressor and you’re done
Imran Latif
158 Reputation
1 Guide authored
5 Guide Comments
do you know the replacement part numbers just in case?
myke - Reply
The replacement parts are not listed in the manual and not available for sale. Hence this workaround.
Imran Latif - Reply
what type of spring did you replace it with?
Gaeilge 6 - Reply
Random screw I found from a 3D printer part. Size and shape were both different than the original spring. As long as the dimension are similar to 6mm wide and 20mm tall, it would work. The spring I used was not 6mm by 2omm but close enough that it worked.
Imran Latif - Reply
Replaced and still leaks. Tried replacing o ring and still leaks.
Rollin Blanton - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 91
All Time: 1,499
