DYMO LabelPOINT 100 Cutting Blade Replacement
  1. DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: step 1, image 1 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: step 1, image 2 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Rear Panel: step 1, image 3 of 3
    • Slide the panel release button.
    • Lift the panel.
  2. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Label Tape Cassette: step 2, image 1 of 2 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Label Tape Cassette: step 2, image 2 of 2
    • Firmly press the cartridge release button with your finger.
    • You may need to hold the cassette and/or entire device still while pressing the button.
    • Lift the label tape cassette out of the device.
  3. DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: step 3, image 1 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: step 3, image 2 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Blade Disassembly: step 3, image 3 of 3
    • Use Phillips #00 Screwdriver to disengage cutter from device
    • Remove cutter
  4. DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: step 4, image 1 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: step 4, image 2 of 3 DYMO LabelPOINT 100 Cutting Blade Replacement, Remove Blade: step 4, image 3 of 3
    • Use Phillips #00 screw to unscrew blade from blade cutter
    • Carefully remove blade. The blade is sharp and can be dangerous if not handled properly.
    • Replace blade
Dustin Holifer
207 Reputation
2 Guides authored
USF Tampa, Team 5-2, Mcgee Fall 2014 Member of USF Tampa, Team 5-2, Mcgee Fall 2014
USFT-MCGEE-F14S5G2
4 Members
6 Guides authored
One Comment
dangerous? Really :) haha anyway nice review.
speedy - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 2,591
