Dashcam DOD LS300W Battery Replacement
  1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: step 1, image 1 of 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: step 1, image 2 of 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: step 1, image 3 of 3
    • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
  2. Dashcam DOD LS300W Battery Replacement: step 2, image 1 of 2 Dashcam DOD LS300W Battery Replacement: step 2, image 2 of 2
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Dashcam DOD LS300W Battery Replacement: step 3, image 1 of 3 Dashcam DOD LS300W Battery Replacement: step 3, image 2 of 3 Dashcam DOD LS300W Battery Replacement: step 3, image 3 of 3
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  4. Dashcam DOD LS300W Battery Replacement: step 4, image 1 of 1
    • Put the dashcam back together.
    • Charge the battery to the full level, and you are ready to go.
Once again, thank you for checking out this guide and I hope it helped!
2 other people completed this guide.
Pierre
542 Reputation
3 Guides authored
2 Comments
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - Reply
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - Reply
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 23
All Time: 6,435
