David Clark Over-Ear Headphones Right Dome Replacement
  1. David Clark Over-Ear Headphones Right Dome Replacement, Right Dome: step 1, image 1 of 3 David Clark Over-Ear Headphones Right Dome Replacement, Right Dome: step 1, image 2 of 3 David Clark Over-Ear Headphones Right Dome Replacement, Right Dome: step 1, image 3 of 3
    • This is the headset that will get both domes replaced. This guide is for the right side dome only.
    • Missing retainer pins are obvious.
    • This is where the retainer rings would be normally sitting to hold the dome to the stirrup
    • I always wonder who owned the equipment before and what the story is behind those initials
  2. David Clark Over-Ear Headphones Right Dome Replacement: step 2, image 1 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 2, image 2 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 2, image 3 of 3
    • Since the retainers are missing, just pulling up on the stirrup
    • will release the dome.
    • Same thing on the other side
  3. David Clark Over-Ear Headphones Right Dome Replacement: step 3, image 1 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 3, image 2 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 3, image 3 of 3
    • Here is the dome free of the stirrup.
    • The earseal is in decent condition. The filter (foam) shows plenty of wear and markings.
    • The earseal is held on by a groove in the dome. Simply pulling it off will release it.
  4. David Clark Over-Ear Headphones Right Dome Replacement: step 4, image 1 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 4, image 2 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 4, image 3 of 3
    • Earseal removed from dome, filter visible.
    • Next remove the filter (foam) to visualize the speaker.
    • Remove the next filter (foam) that is layered around the speaker
  5. David Clark Over-Ear Headphones Right Dome Replacement: step 5, image 1 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 5, image 2 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 5, image 3 of 3
    • Filter removed, and another filter is visible around the speaker. The original headset will have three filters
    • One more filter under the speaker that needs to be removed.
    • The two screws that hold the speaker to the dome are clearly visible
  6. David Clark Over-Ear Headphones Right Dome Replacement: step 6, image 1 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 6, image 2 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 6, image 3 of 3
    • These are the two slotted screws that hold the speaker to the dome
    • Remove those with a flathead screw driver
    • Once the two screws are loose, lift the speaker out of the dome.
  7. David Clark Over-Ear Headphones Right Dome Replacement: step 7, image 1 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 7, image 2 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 7, image 3 of 3
    • Flip the speaker out of the dome to remove the last filter.
    • With the speaker and the filter removed, damage to a standoff for the speaker becomes evident
    • The speaker wires are held in place by two slotted screws
  8. David Clark Over-Ear Headphones Right Dome Replacement: step 8, image 1 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 8, image 2 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 8, image 3 of 3
    • Loosen the two screws to remove the speaker
    • Pull the speaker wire (overhead cord) to the inside of the dome to free the cord clip
    • Using a pair of combination pliers, squeeze the two tabs of the cord clip
  9. David Clark Over-Ear Headphones Right Dome Replacement: step 9, image 1 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 9, image 2 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 9, image 3 of 3
    • This will open the cord clip
    • Remove the cord clip
    • Pull the speaker wire (overhead cord) out of the dome.
  10. David Clark Over-Ear Headphones Right Dome Replacement: step 10, image 1 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 10, image 2 of 3 David Clark Over-Ear Headphones Right Dome Replacement: step 10, image 3 of 3
    • Here is the damage of the speaker standoff
    • Remove the rubber grommet from the speaker cable opening by using a jewelers screw driver. Gently use the screw driver to push the lip out of the opening.
    • Removed rubber grommet.
  11. David Clark Over-Ear Headphones Right Dome Replacement: step 11, image 1 of 1
    • Here is the old dome ready to be replaced with a new one.
oldturkey03
791,229 Reputation
119 Guides authored
Global Fixers Member of Global Fixers
Community
35 Members
603 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 1,843
