DeLonghi ETAM Opening side panels
  1. DeLonghi ETAM Opening side panels, DeLonghi ETAM Opening side panels: step 1, image 1 of 2 DeLonghi ETAM Opening side panels, DeLonghi ETAM Opening side panels: step 1, image 2 of 2
    • Disconnect the power plug and remove the power cord from the device.
    • Remove all coffee beans. Remove all attachments such as drip tray, milk frother and water tank. Open the service door and remove the brew group.
    • Unscrew the two Phillips screws
    • The Phillips screw under the water tank can remain.
  2. DeLonghi ETAM Opening side panels: step 2, image 1 of 2 DeLonghi ETAM Opening side panels: step 2, image 2 of 2
    • The bean compartment flap must be removed. It is latched on the left and right, the latch is held under tension by a spring. Compress the spring until the catch is free and lift off the flap.
  3. DeLonghi ETAM Opening side panels: step 3, image 1 of 3 DeLonghi ETAM Opening side panels: step 3, image 2 of 3 DeLonghi ETAM Opening side panels: step 3, image 3 of 3
    • There is a plastic cover strip under the flap. It is only latched in place. Release it with a flat tool and lift it out.
  4. DeLonghi ETAM Opening side panels: step 4, image 1 of 2 DeLonghi ETAM Opening side panels: step 4, image 2 of 2
    • Lift the back side up and put it aside.
  5. DeLonghi ETAM Opening side panels: step 5, image 1 of 2 DeLonghi ETAM Opening side panels: step 5, image 2 of 2
    • The side covers are still attached to the back with two screws. They are located under a cover strip that is only snapped in place. Take off the cover strip and put it aside.
    • Unscrew the two Phillips screws.
  6. DeLonghi ETAM Opening side panels: step 6, image 1 of 2 DeLonghi ETAM Opening side panels: step 6, image 2 of 2
    • Push the left side panel back about 1 cm. It often jams strongly and you have to help it with a plastic opening tool.
    • Remove the left side panel.
  7. DeLonghi ETAM Opening side panels: step 7, image 1 of 1
    • The right side panel is removed in the same way, but the service hatch is a bit obstructive. Open it first and push the side panel back a few millimeters. This is often difficult and you will need a plastic lever tool.
    • Close the flap again and push the sides further back. It is a bit tricky and you have to work carefully. Lift out the side panel.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
shingle is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
315,732 Reputation
309 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 71
All Time: 2,214
