DeWALT Hammer Drill DW511 Lever Assembly Replacement
  1. DeWALT Hammer Drill DW511 Lever Assembly Replacement, Back Cover: step 1, image 1 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Back Cover: step 1, image 2 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Back Cover: step 1, image 3 of 3
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 2, image 1 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 2, image 2 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 2, image 3 of 3
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. DeWALT Hammer Drill DW511 Lever Assembly Replacement, Power Cord: step 3, image 1 of 2 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Power Cord: step 3, image 2 of 2
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 4, image 1 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 4, image 2 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 5, image 1 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 5, image 2 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 5, image 3 of 3
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 6, image 1 of 1
    • With both wires free, the power cord is free from the trigger body.
  7. DeWALT Hammer Drill DW511 Lever Assembly Replacement, Brushes: step 7, image 1 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Brushes: step 7, image 2 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Brushes: step 7, image 3 of 3
    • Use an opening tool to lift up the spring holding down the brush.
    • Remove the brush from its holding.
  8. DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 8, image 1 of 2 DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 8, image 2 of 2
    Buy
    • With a pair of blunt nose tweezers, grab the red wire.
  9. DeWALT Hammer Drill DW511 Lever Assembly Replacement, Lever Assembly: step 9, image 1 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Lever Assembly: step 9, image 2 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement, Lever Assembly: step 9, image 3 of 3
    • Remove two 45 mm T20 Torx screws.
    • Remove one 30 mm T20 Torx screw.
  10. DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 10, image 1 of 1
    • Pull off the top case and set it aside.
  11. DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 11, image 1 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 11, image 2 of 3 DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 11, image 3 of 3
    • Grab the gear case cover and gently pull it out just enough to where it exposes the lever assembly.
    • It is important that the brushes are removed before you do this step or you may damage your brushes.
    • The lever assembly can now be lifted out.
  12. DeWALT Hammer Drill DW511 Lever Assembly Replacement: step 12, image 1 of 1
    • With the old lever assembly removed you can now replace it with a new one.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 413
