DeWALT Hammer Drill DW511 Trigger Replacement
  1. DeWALT Hammer Drill DW511 Trigger Replacement, Back Cover: step 1, image 1 of 3 DeWALT Hammer Drill DW511 Trigger Replacement, Back Cover: step 1, image 2 of 3 DeWALT Hammer Drill DW511 Trigger Replacement, Back Cover: step 1, image 3 of 3
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. DeWALT Hammer Drill DW511 Trigger Replacement: step 2, image 1 of 3 DeWALT Hammer Drill DW511 Trigger Replacement: step 2, image 2 of 3 DeWALT Hammer Drill DW511 Trigger Replacement: step 2, image 3 of 3
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. DeWALT Hammer Drill DW511 Trigger Replacement, Power Cord: step 3, image 1 of 2 DeWALT Hammer Drill DW511 Trigger Replacement, Power Cord: step 3, image 2 of 2
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. DeWALT Hammer Drill DW511 Trigger Replacement: step 4, image 1 of 3 DeWALT Hammer Drill DW511 Trigger Replacement: step 4, image 2 of 3 DeWALT Hammer Drill DW511 Trigger Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. DeWALT Hammer Drill DW511 Trigger Replacement: step 5, image 1 of 3 DeWALT Hammer Drill DW511 Trigger Replacement: step 5, image 2 of 3 DeWALT Hammer Drill DW511 Trigger Replacement: step 5, image 3 of 3
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. DeWALT Hammer Drill DW511 Trigger Replacement: step 6, image 1 of 1
    • With both wires free, the power cord is free from the trigger body.
  7. DeWALT Hammer Drill DW511 Trigger Replacement, Brushes: step 7, image 1 of 3 DeWALT Hammer Drill DW511 Trigger Replacement, Brushes: step 7, image 2 of 3 DeWALT Hammer Drill DW511 Trigger Replacement, Brushes: step 7, image 3 of 3
    • Use an opening tool to lift up the spring holding down the brush.
    • Remove the brush from its holding.
  8. DeWALT Hammer Drill DW511 Trigger Replacement: step 8, image 1 of 2 DeWALT Hammer Drill DW511 Trigger Replacement: step 8, image 2 of 2
    Buy
    • With a pair of blunt nose tweezers, grab the red wire.
  9. DeWALT Hammer Drill DW511 Trigger Replacement, Trigger: step 9, image 1 of 3 DeWALT Hammer Drill DW511 Trigger Replacement, Trigger: step 9, image 2 of 3 DeWALT Hammer Drill DW511 Trigger Replacement, Trigger: step 9, image 3 of 3
    Buy
    • Carefully wiggle the wire loose until it comes out.
  10. DeWALT Hammer Drill DW511 Trigger Replacement: step 10, image 1 of 3 DeWALT Hammer Drill DW511 Trigger Replacement: step 10, image 2 of 3 DeWALT Hammer Drill DW511 Trigger Replacement: step 10, image 3 of 3
    • Grab a pair of blunt nose tweezers and clamp the wire.
    • Slowly pull the wire out until it is free.
    • The trigger is now free from the drill.
0 Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 29
All Time: 1,112
