DeWalt D28110 Brush Arm Replacement
  1. DeWalt D28110 Brush Arm Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: step 1, image 1 of 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Brush Arm Replacement: step 2, image 1 of 1
    • Use the edge of the spudger to loosen and remove the back panel.
  3. DeWalt D28110 Brush Arm Replacement: step 3, image 1 of 1
    • Remove the single 20-mm torx screw holding the rear panel in place.
  4. DeWalt D28110 Brush Arm Replacement: step 4, image 1 of 1
    • Pull back the rear side of the back panel.
  5. DeWalt D28110 Brush Arm Replacement, Brush Arm: step 5, image 1 of 1
    • Using the T-6 screwdriver, unscrew torx screw holding the arm in place.
  6. DeWalt D28110 Brush Arm Replacement: step 6, image 1 of 1
    • Gently remove the arm from the assembly.
Kean Wee
495 Reputation
4 Guides authored
Cal Poly, Team 18-6, Maness Winter 2015 Member of Cal Poly, Team 18-6, Maness Winter 2015
CPSU-MANESS-W15S18G6
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 2,376
