DeWalt D28110 Pinion Replacement
  1. DeWalt D28110 Pinion Replacement, Disassembling DeWalt D28110 Gear Case: step 1, image 1 of 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Pinion Replacement: step 2, image 1 of 2 DeWalt D28110 Pinion Replacement: step 2, image 2 of 2
    • Pull out the gear case.
  3. DeWalt D28110 Pinion Replacement, Pinion: step 3, image 1 of 2 DeWalt D28110 Pinion Replacement, Pinion: step 3, image 2 of 2
    • Using the T-15 screwdriver, remove the four torx screws.
  4. DeWalt D28110 Pinion Replacement: step 4, image 1 of 1
    • Remove the gear case cover from the gear case.
  5. DeWalt D28110 Pinion Replacement: step 5, image 1 of 3 DeWalt D28110 Pinion Replacement: step 5, image 2 of 3 DeWalt D28110 Pinion Replacement: step 5, image 3 of 3
    • Using a 10-mm wrench, remove the hex nut by rotating counter-clockwise.
  6. DeWalt D28110 Pinion Replacement: step 6, image 1 of 2 DeWalt D28110 Pinion Replacement: step 6, image 2 of 2
    • Remove the armature assembly from the gear case.
    • Remove the pinion from the armature assembly.
2 other people completed this guide.
Will Young
266 Reputation
2 Guides authored
Cal Poly, Team 18-6, Maness Winter 2015 Member of Cal Poly, Team 18-6, Maness Winter 2015
CPSU-MANESS-W15S18G6
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 13
All Time: 2,262
