DeWalt DC970 Battery Fuse Replacement
  1. DeWalt DC970 Battery Fuse Replacement, Battery Fuse: step 1, image 1 of 2 DeWalt DC970 Battery Fuse Replacement, Battery Fuse: step 1, image 2 of 2
    • Remove the four 13 mm, Torx Security #15 screws found on the bottom of the charger.
  2. DeWalt DC970 Battery Fuse Replacement: step 2, image 1 of 2 DeWalt DC970 Battery Fuse Replacement: step 2, image 2 of 2
    • Remove the 19 mm, Torx Security #10 screw found in the charger port.
    • Then pull the top of the charger off separating it from the bottom.
  3. DeWalt DC970 Battery Fuse Replacement: step 3, image 1 of 1
    • Locate the fuse and pull it out with two fingers.
    • Once you have located the fuse, if you have the replacement fuse just pull the old one out and put the new one in.
    • Replacement fuses can be found in hardware stores.
4 other people completed this guide.
Antonia Thomas
411 Reputation
1 Guide authored
1 Guide Comment
Can i get some help in locating the fuse in mt dcb 112 dewalt battery charger i cant found it
bigboyf232 - Reply
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 84
All Time: 19,722
