DeWalt DCF885 Selector Switch Replacement
  1. DeWalt DCF885 Selector Switch Replacement, Battery: step 1, image 1 of 1
    • Press the battery release button at the top of the battery.
  2. DeWalt DCF885 Selector Switch Replacement: step 2, image 1 of 1
    • Pull the battery away from the tool.
  3. DeWalt DCF885 Selector Switch Replacement, Motor Assembly: step 3, image 1 of 1
    • Remove the eight 18 mm Torx Security #10 screws.
  4. DeWalt DCF885 Selector Switch Replacement: step 4, image 1 of 1
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. DeWalt DCF885 Selector Switch Replacement: step 5, image 1 of 1
    • Disconnect the connector from the motor assembly.
  6. DeWalt DCF885 Selector Switch Replacement: step 6, image 1 of 1
    • Pull the motor away from the brush assembly.
  7. DeWalt DCF885 Selector Switch Replacement, Brush Assembly: step 7, image 1 of 1
    • Lift the brush assembly out of the drill case.
  8. DeWalt DCF885 Selector Switch Replacement: step 8, image 1 of 1
    • Pull the armature assembly apart from the brush ring assembly.
  9. DeWalt DCF885 Selector Switch Replacement: step 9, image 1 of 1
    • Pry the two circled connectors apart from the brush ring assembly.
  10. DeWalt DCF885 Selector Switch Replacement: step 10, image 1 of 1
    • The brush assembly is now removed from the drill body.
  11. DeWalt DCF885 Selector Switch Replacement, Switch Assembly: step 11, image 1 of 1
    • Pull the switch assembly up and out of the drill case.
  12. DeWalt DCF885 Selector Switch Replacement, Selector Switch: step 12, image 1 of 1
    • Pull the selector switch out from the outer case.
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 27
All Time: 854
