DeWalt DW660 Bearings Replacement
  1. DeWalt DW660 Bearings Replacement, Bearings: step 1, image 1 of 1
    • Pull off the depth guide.
    • If the guide doesn't come away easily, use a twisting motion to pull it from the tool.
  2. DeWalt DW660 Bearings Replacement: step 2, image 1 of 3 DeWalt DW660 Bearings Replacement: step 2, image 2 of 3 DeWalt DW660 Bearings Replacement: step 2, image 3 of 3
    • Hold down lock #1 to prevent the motor from spinning.
    • While holding lock #1, hold down lock #2 as well.
    • Rotate lock #2 counterclockwise to unscrew the collet nut.
  3. DeWalt DW660 Bearings Replacement: step 3, image 1 of 1
    • Remove the collet nut and the collet from the device.
  4. DeWalt DW660 Bearings Replacement: step 4, image 1 of 2 DeWalt DW660 Bearings Replacement: step 4, image 2 of 2
    • Unscrew the four 19mm T20 Torx screws on the motor shroud.
    • Carefully remove the shroud from the body.
    • When removing the shroud, the spring that operates lock #2 may pop out.
  5. DeWalt DW660 Bearings Replacement: step 5, image 1 of 3 DeWalt DW660 Bearings Replacement: step 5, image 2 of 3 DeWalt DW660 Bearings Replacement: step 5, image 3 of 3
    • Unscrew the four 19mm T20 Torx screws on the side of the back end of the DW660.
    • Take apart the back two halves.
    • Using two fingers, pull the black and white power wires from the motor to completely disconnect the back half of the device.
  6. DeWalt DW660 Bearings Replacement: step 6, image 1 of 2 DeWalt DW660 Bearings Replacement: step 6, image 2 of 2
    • Lift the coiled spring from the back of the brush using a spudger.
    • While holding the spring out of the way, use a pointed spudger to slide the carbon brush up out of the guide.
    • Slowly release the brush spring. It will sit in the brush guide.
    • Repeat this step for the second brush.
  7. DeWalt DW660 Bearings Replacement: step 7, image 1 of 1
    • Pull the rotor out of the front of the DW660.
    • Be very careful to make sure the rotor does not collide with the stator. The stator coils or the commutator can be damaged very easily.
  8. DeWalt DW660 Bearings Replacement: step 8, image 1 of 1
    • Remove the snap ring from the bearing by using snap ring pliers.
    • This will take some force and the snap ring will act as a spring, so be careful to make sure the ring does not fly off the pliers.
  9. DeWalt DW660 Bearings Replacement: step 9, image 1 of 1
    • Pull the black plastic bearing block off of the motor shaft.
    • Remove the ball bearing from the bearing block.
  10. DeWalt DW660 Bearings Replacement: step 10, image 1 of 2 DeWalt DW660 Bearings Replacement: step 10, image 2 of 2
    • Remove the rubber cap from the bearing.
    • Use the bearing puller to remove the bearing from the shaft.
    • When installing the new bearings, it may help to use a small hammer and a hollow circular pipe with the same outer diameter as the inner ring of the bearing.
Ryan Owen Rheaume
405 Reputation
1 Guide authored
One Comment
What size bearing does it take?
James Armstrong - Reply
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 17
All Time: 822
